01-14-2008, 03:18 PM
91 Wildcat Mountain Wont Start
HEY FOLKS WONDERING IF ANYONE CAN HELP,
91 WILDCAT IS GIVING ME FITS, WE WERE GOING FOR A RIDE HAD ALL THE SLEDS RUNNING, 91 CUT OUT , WOULDNT RESTART , BROUGHT IT HOME CHECKED IT OUT AND FOUND NO FUEL IN THE FILTER, (JUST A FEW DROPS)
REMOVED THE FUEL LINE FROM THE FILTER AND NO FUEL RAN OUT OF THE TANK ( YES HALF A TANK) TOOK AN AIR HOSE AND BLOW AIR INTO THE HOSE.... NOTHING.
THEN BLEW AIR INTO THE TANK... SMALL AMOUNT OF GAS CAME OUT, REPLACED FUEL LINE AND PRIMED THE SLED IT STARTS BUT WONT STAY RUNNING, STILL NO FUEL IN THE FILTER. ITS MONDAY WIFE AND FRIENDS ARE TAKING ALL OUR SLEDS UP NORTH TO RIDE FRIDAY, I NEED HELP.......  BY THE WAY ITS CARBERATED
THANKS FOR ANY HELP......
01-14-2008, 09:00 PM
THere's obviously an obstruction of some sort in the tank. Fuel should come right out of the line. Is there anything between the line you pulled off and the tank (ie, fuel pump, etc.)?
01-15-2008, 12:09 AM
Also, maybe the pickup line came off in the tank.
Once it gets below half full, it can't get any fuel.
01-15-2008, 04:00 AM
Ok First Were I Took The Fuel Line Off Is Right At The Tank , Before The Filter, I Can Now See Fuel At The Filter But Nothing In The Filter.
Today I Will Go Buy A New Filter, And See How That Goes, Still Not Sure How Much Fuel Is In The Line Or If It Will Run Out When I Pull The Line Off The Filter.
Some One Said Somthing About A Pick Up Hose, How Can You Tell If Its Off, And How Do You Get It Back On , Is It Connected To The Fuel Shut Off Valve?
I Would Like To Thank You For Replying To My Questions,this Is My First Time Here And It Seems Like There Are Some Really Nice Folks Here,some Of The Others I Saw , The People Just Wanted To Rip On Each Other. Thank You Again And Hope You Get Lots Of Snow Its Snowing Now Here In Detroit.:d
01-15-2008, 10:11 AM
This may sound stupid but Make a seal over the filler side in the tank where your gas cap is and blow. I did that to one of my powders and had some air blockage neve rhad a problem since.
Co Springs Co
1999 Powder Special 700 1500 miles
1999 Powder Special RIP
2003.5 Mountain Cat 900 Mod Sled
1998ish zr600 In the mad scientists garage getting some new guts and mods...Should be interestin.
01-15-2008, 01:03 PM
Since you have a half full tank, apply some suction to the fuel line or pressure into the tank and see if you get any fuel. If not, you can take the fitting off th tank and see if the line is still there.
01-15-2008, 02:58 PM
91 Wildcatmountain Wont Start
Hey Guys ,
Thanks For All The Tips, Here Is An Update.
Replaced The Fuel Line And Filter Today, Have About A 1/4 Tank Of Gas, Pressureized The Tank , I Could See Gas Sort Of Spraying Into The Fuel Line Right Up To The Carb , But Still Did'nt Fill The Filter.
Sprayed Some Either Into The Jugs And It Started Right Up And Ran For About 2 Minutes, Probly Ran Out The Fuel That I Forced Into The Lines.
So I Now Know The Filter And Lines Are Clear, But Still No Fuel Being Pulled Into The System.
One Of You Said Maybe The Pick-up Line Fell Off, Well The Fuel Valve Is Right Next To The Oil Tank And Coolant Overflow So Just Taking The Valve Off Is More Of A Chore, Iam Going To Try Filling The Tank And See Want Happens.
Stay Tuned, I Will Keep You Informed
Thanks Again:d
01-15-2008, 08:59 PM
Before you fill the tank, you said you blew into the tank from the filter? You likly blew the pick up line off! Take a flash light and a coat hanger and go fishing! There is about a 16" piece of fuel line and a brass screen on the end in the tank! with about 1/4 of a tank unscrew the fitting on the tank where the fuel line goes and the pickup line will go on the other end! Cut an inch off both ends, heat up the hose and really push to get it back on! Put her back together and with the gas cap off blow into the tank, this will flow gas to the pump. It would also be good to remove the pump and atleast clean it, just make note of where all the hoses go to! Good luck!
01-16-2008, 02:53 PM
Just Wanted To Let U All Know It Worked, The Sled Is Up And Running Thanks Too All Your Help.
You Guys Are A Life Saver, Wow Never Thought About The Pick Up Line......
Guess Your Never To Old To Learn, But Now I Have A Line Of Sleds From Friends Waiting For Me( Us) To Work On Them.
Have Told All The Club Members Here About This Site And How Helpful Everyone Was ......thanks Again
01-17-2008, 09:23 AM
Well, when you told us that it ran until it got to 1/2 tank, we knew exactly what happened.
Good that you have it fixed. Get you friends to join here too, the more the merrier.
