01-14-2008, 09:09 AM
Newbie doing engine swap soon !
I have a 1976 Jag i thought it was a 78. . .
It has the 275cc engine I want to do like resto rod type project with this mechine. . .
I was thinking of running the 900cc triple than i changed my mind to 600cc triple. . .
What engine's would make good sleeper that would be easyer to find and make fit ?
I'd like to go atleast 440cc or bigger !
Mike
01-14-2008, 09:22 AM
I'd do a ZR600(twin), they are readily avalible for under a grand and can make up to about 150hp! The next step would be a ZR900 (twin) but then you are looking at over a grand for the motor alone!
Triples in that sled wont fit! And you'd never get a set of pipes to work! The exhaust is the most important part of a sleeper! Any performance engine you put in there Must have a good exhaust or it won't run! If you could get a T Cat 1000 in there Capable of over 200HP and then butcher up a set of pipes you would be lucky to get 100hp out of it!
01-14-2008, 02:45 PM
i would be worried if the stock parts can handle the stress of a 900cc motor.  im just not sure how reliable it would be. just my .02 cents. but it could be fine, i wouldn't know.
'94 Arctic Cat EXT 580
01-14-2008, 03:15 PM
thats true but how much power would one really need ? the old 275cc is pushing what 8-12hp ? 25top's ? How much power would one need to push a Jag 2000 ? 75-125hp ?
Tho i do see what you mean about the exhuast, When i was thinking of running the 900 triple i was thinking of running the pipes threw the hood . . . not very stealthy tho !
I like the sound of the 600 twin! that sounds plenty beefy i have a tendoncey to go over bord. . .
Mike
01-14-2008, 03:20 PM
My plan was use as much of the higher output power plant as could engine clutches ECT.
this is going to be a toy!
i'm running it as this year than next year i'm going to get a more up to date driver say late 80's early 90's nice simple runner. . .
I was planning to build this over the summer or so. . .
76 Jag $200
Big power plant $1,500
passing a pack of late model sleds on the wide straight with 30 year old relic priceless. . .
that tis the goal anyhow . . .
Mike
01-15-2008, 01:25 AM
Sounds like a fun idea
Remember to check if you can fit the gearbox, and a drive shaft that can handle the power.. before you weld the enginemounts in!
It's a lot of work customizing the frame and enginemounts, but once you are done you will have the biggest smile in your county!
'07 Polaris Switchback 600 HO - New project,Dragon to come
'06 Polaris Fusion 600. (Wrecked )
'00 SKS 500, '05 M5
http://www.sas-as.no/sledblog
01-15-2008, 10:08 AM
There are still a few of the Vintage sleds out there that can do what you just said, stock!!! First one that comes to mind is a 76 Yami SRX! And there are alot more! If I was to build a sleeper I would start with something lighter, maybe an old John Deer? Or Exciter something in the 300# range?
01-15-2008, 02:37 PM
[quote=kccats]There are still a few of the Vintage sleds out there that can do what you just said, stock!!! First one that comes to mind is a 76 Yami SRX! And there are alot more! If I was to build a sleeper I would start with something lighter, maybe an old John Deer? Or Exciter something in the 300# range?[/QUOTE
I'm using the CAT ! as i already have it.
i'm not into the other brands never really owned them so i'm going with what i'm comfortable with !
I ended up getting this cat for free instead of orginal $200 . . .
Mike
01-16-2008, 10:04 AM
I think i'm just going to put 440 dual carb engine in there should be almost a drop in bolt up and go !
or atleast thats what i'm getting told by the guy's around here off they all seem to say go with the 440dual carb fan cooled or air cooled engine. . .tho one older fella thinks the 440 liquid cooled would give the best power. . .
I'm almost thinking with all the differing opinions i should maybe just be happy to have a running 275 and enjoy all of its slow and doggyness cause hey after all it's faster than walking. . .
 440
Mike
01-16-2008, 11:02 AM
Even a 340 twin would surprise you with it's power increase from what you have in there now.
Putting a liquid cooled in there would be way more work (easier to just get another sled).
Let's not forget about a 500cc fan to go in there as well.
01-16-2008, 12:19 PM
A 500cc fan cooled would drop right in ?
about what dose that turn for power ? i'm still woundering about what i got for power . . .
275ccHP:
340ccHP:
440ccHP:
500ccHP:
I'm guessing from what have been hearing it all of these are my option's the 440 fan cooled seems to be the popular choice. . .
I would like to know the power difference between these engine's. . .
do they offer a twin carb 500cc dual carb ?
Mike
01-16-2008, 12:23 PM
Get a later model 500cc Fan from a cougar. Then bore it out and clean up the ports. By going with one of those motors you would leave yourself a ton of budget to modify....did someone say blue bottle......
We did this with a rupp nitro american body back in the mid 90's
Took a 440 John Deer Motor bored over and then put a blue bottle on it. That sled looked like complete crap but it was phenomenal. He used to watch the look on peoples faces in the fields back east when he would pull up on these new sleds and just kill em lol. The sled only lasted 6 shots but it was fun lol. We drove an entire season without using many shots but when those oppurtunities came up man was it funny.
Ultimately that sled melted down lol
Co Springs Co
1999 Powder Special 700 1500 miles
1999 Powder Special RIP
2003.5 Mountain Cat 900 Mod Sled
1998ish zr600 In the mad scientists garage getting some new guts and mods...Should be interestin.
01-16-2008, 12:34 PM
So i should be on the look out for 500cc fan cooled Engine !
thank's for the help guy's. . .
Mikey D
01-16-2008, 01:16 PM
Craigs list search all over the country I found one in an evening for my last swap.
Co Springs Co
01-16-2008, 02:35 PM
Try to catch my CAT
I'd try to get a 600 or 700 liquid twin.
ARCTIC CAT
Worthington Flip Top Trailer
01-16-2008, 05:02 PM
i wouldnt wanna run all that plumbing...
Co Springs Co
01-16-2008, 07:06 PM
1st Assistant Highjacker
Why dont you try looking for a newer 570cc fan cooled? Those are probly be best fan cooled engines in terms of hp numbers and reliability.
01-18-2008, 04:32 PM
I found a 1981 Arctic cat Pantera with a 87 couger
500cc fan cooled with dual carbs, Engine only has 1,250 miles since rebuilt he wants $250 cash for it sled is all beat to heck but i would have the power plant and running gear !
Mike
01-18-2008, 04:54 PM
#19 (permalink)
There you go, put the rubber track and all under the Jag and the 500 fan in there with the original sprocket ratio and it will haul A@@.
01-19-2008, 12:13 AM
#20 (permalink)
I paid the same for the motor I used in the frankenpanthernightmare.... Anyway ran fast when I had it workin. Plus you get the skis etc..
Co Springs Co
