Hello all, I have just picked up a 94 prowler 440 EFI, my first sled ever. I put a new battery in it since it has been sitting for the past 3 years. It turned over and ran, at least idled well. I finished putting the exhaust on that the previous owner took off. I then put the sled in it's side to get the old gas out. After that it started not to run at all. It has spark and is getting A LOT of fuel! It will hardly idle. I chased all the wires and all connections, nothing is wrong there. When it is running it barely keeps running. I pull on the throttle and it dies on it's face. I checked the cylinders and they were overloaded with fuel. I let the fumes out and tried it? Since this is my first sled I need a little help. Heard good things about this forum so here I am. I have a full garage and use to work on cars way to much! So I have some knowledge when it comes to motors, just not 2 cycles and sleds
So any idea's on bad parts or what I can test to see if it works let me know, thanks
