Old 01-11-2008, 05:35 PM   #1 (permalink)
celicaguy58
celicaguy58's Avatar
speedometer key problem
Im putting my sled back together after changing the drive bearings. i trying bolt on the speedo cover but the key is stopping it, not allowing the cover to be flush with the side. it is about 1/4 to 1/8 inch away. i have already removed the two old parts of the key. is it possible that the new key is too long. the two old parts look to be shorter than the new one. or could the shaft be too far too the left?
'94 Arctic Cat EXT 580
celicaguy58 is offline   Reply With Quote
Old 01-11-2008, 06:11 PM   #2 (permalink)
SkiDooFormulaMX
GO GREEN OR GO HOME!
SkiDooFormulaMX's Avatar
the shaft should shift into place as you tighten it, it is possible the key is too long, i just did mine too but i didnt replace the key as i am never looking down anyway. if you say theyre longer than they likely are. make sure the bearing is in the same spot it was when you took it off also.
2003 ARCTIC CAT ZL 600 EFI SS-2700 MILES-GETTING SOME MILD TWEAKING THIS SUMMER
2002 ARCTIC CAT Z 440 ES-622 MILES-MINT, JUST LOOKING FOR SOME STUDS AND FATBOY TORSIONS.
1997 ARCTIC CAT EXT 580 EFI DLX 4000 MILES-SOLD 8/08
1998 ARCTIC CAT ZR 600 EFI-3700 MILES-BUILT-SOLD-9/07
1996 INDY CLASSIC 500 ESR-5100 MILES-SOLD 4/08
1987 SKI DOO FORMULA MX 470-12000 MILES-SOLD 12/07
SkiDooFormulaMX is offline   Reply With Quote
Old 01-11-2008, 06:13 PM   #3 (permalink)
celicaguy58
the bearing appears to be in the same spot. but im not certain.
Old 01-12-2008, 01:05 AM   #4 (permalink)
The bearing should be flush with the end of the shaft.
You may have the wrong key.
Old 01-12-2008, 10:42 AM   #5 (permalink)
kccats
Will the drive fit without the key?
Old 01-13-2008, 12:40 AM   #6 (permalink)
celicaguy58
yes the drive fit without the key. i ended up just cutting a 1/4 inch off and it worked.
