Old 01-11-2008, 12:34 AM   #1 (permalink)
paintballdude05
1st Assistant Highjacker
paintballdude05's Avatar
For Ditch hopper
Here is the pick, 1 is where you should be measuring, idler wheel to side of track. #2 is the lenght of the adjuster bolt. Dont know how accurate this is to gauge it but in theore you have both the same lenght and should have the same lenght on both sides for # 1. Get it now .
Old 01-11-2008, 12:37 AM   #2 (permalink)
Ditch hopper
2nd Assistant Highjacker
Ditch hopper's Avatar
I GET IT yessss! and btw how often do yah get a thread named after yah
Real men Hijack threads
-1995 zr580- aaen pipe, epi clutch kit, camoplast ripsaw/120studs, 3inch riser, flybars, upgraded foxshocks, weisco pistons, lightly ported, 19tooth top 32thooth bottom soon to come bored carbs, plastic skis, new helix and ramps BRAAAP
Ditch hopper is offline   Reply With Quote
Old 01-11-2008, 12:38 AM   #3 (permalink)
paintballdude05
Not often lol, good night going to bed
Old 01-11-2008, 08:55 AM   #4 (permalink)
tamacat
Try to catch my CAT
tamacat's Avatar
#1 would be more accurate.
ARCTIC CAT
Worthington Flip Top Trailer
Old 01-11-2008, 03:36 PM   #5 (permalink)
Actually, if you get #2 even, #1 will be even also. Easier to measure the bolt than the track offset.
I use a depth gauge (bar caliper) to make sure that both bolts are even.
Old 01-12-2008, 12:49 AM   #6 (permalink)
paintballdude05
But if you got some binding that you are not aware of in the idler wheel shaft guide thing(if you know what I mean), this has hapend to me and have the two bolts equal then it can be off. But in most situations it will be acurate though mesuring from 2.
Old 01-12-2008, 01:10 AM   #7 (permalink)
That's why you run in the track after adjustment and recheck for alignment.
Old 01-13-2008, 07:34 AM   #8 (permalink)
kccats
The most important is to check at the upper wheel, the distance between the track and the tunnel! Make both sides the same!
Old 01-13-2008, 03:16 PM   #9 (permalink)
paintballdude05
Interesting point here, if its the same in the back isint it the same up there?
