Old 01-10-2008, 07:29 PM   #1 (permalink)
celicaguy58
celicaguy58's Avatar
chain case gears
i am putting my sled back together after replacing the drive shaft bearings. the lower gear hangs over the edge of the shaft about a 1/8 inch (see pic below). is this normal? the bearing appears to be flush with the hex part of the shaft so it doesnt look like it can move over anymore. also should the bearing have the collar facing out or in?
'94 Arctic Cat EXT 580
celicaguy58 is offline   Reply With Quote
Old 01-10-2008, 07:42 PM   #2 (permalink)
IndianRvrShiver
IndianRvrShiver's Avatar
Should go in the same way it came out!! Does it align with the top gear??
Old 01-10-2008, 07:43 PM   #3 (permalink)
celicaguy58
i took it apart yesterday so i dont remember which way the bearing came off. the top gear is also hanging over about the same.
Old 01-10-2008, 07:53 PM   #4 (permalink)
kccats
The gears hanging over is OK, but take a steel ruler and check the alinment, from across the botom gear to the side of the top, without the chain! The collar should be to the gear side.
Old 01-10-2008, 08:36 PM   #5 (permalink)
celicaguy58
the top gear hangs over a little. and i checked the alignment with a square, and they are in alignment. so it this a common thing?
Old 01-10-2008, 09:44 PM   #6 (permalink)
kccats
Yep you are good to go!
Old 01-10-2008, 10:03 PM   #7 (permalink)
celicaguy58
ok thanks!
