is it possible to hear ping in a snowmobile because my prowler sounds like it pings when i get on it is that possible i would think so but i need expert opinion
Yes it is called preignition and will destroy a motor! Pull your plugs and see if they are very light! Then get a bore light and check the top of the pistons! Bad gas or too much alcohal will do this!
i have wrecked a brandnew wiseco piston that i think that was from detination because it would not go over 45 @WOT and it blew a hole in the piston with only 68MILES in it!!!!!!
