Old 01-09-2008, 05:17 PM   #1 (permalink)
kaneryder
stator removal steps
i need to remove the stator from an '96 arctic cat zrt600. i have no manual for tips so any suggestions would be greatly appreciated
Thanks
kaneryder is offline   Reply With Quote
Old 01-09-2008, 05:51 PM   #2 (permalink)
The stator is located behind the recoil and flywheel. You'll need a good flywheel puller to get it off. A harmonic balancer puller from an auto parts store works the best.
Old 01-10-2008, 12:34 AM   #3 (permalink)
harofreak
If you go to this site, Brown's Leisure World - Home Page you can get an exploded view of what you are working on!! Hope this helps!
harofreak is offline   Reply With Quote
Old 01-10-2008, 09:19 AM   #4 (permalink)
kccats
With the nut and washers remover from the flywheel,spray with PB Blaster, put the nut back on till it's flush. Put three hardened bolts into the flywheel about 1/4 to 5/16" no more! Tighten the puller as tight as you can then hit the end of it with a hammer!Tap and turn till it pops! When it goes it will scare the crap out of you! Make a mark so that you get the stator exactly back where it was!
