Old 01-08-2008, 04:11 PM   #1 (permalink)
garryb1545
Question 1998 zr 600 rear is low
Hi is there any adjustment on a 1998 zr 600 snow pro I find that it is setting low. I looked underneath nothing broken and it don't bottom when riding. Maybe it's just me but I would like for it to sit higher. can I adjust anything to solve this.It has gas shocks and they seem to be fine as well
garryb1545 is offline   Reply With Quote
Old 01-08-2008, 07:26 PM   #2 (permalink)
grouly925
cocky youngster
grouly925's Avatar
There should be a triangle adjustment block that changes the preload on the rear springs (part #18 in the link below). You can adjust this to the thickest of the sides to gain a little height. If this doesn't work, it is probably time for a shock rebuild, even though they may look fine they may be worn out.
http://www.brownsleisureworld.com/Pa...0732-622_s.gif
Country Boys can survive.
2003 F7 EFI Limited Edition Sabrecat Graphics
1-3/8 sno pro track w/ 170 1.450 mega-bites
2.5 degree timing key
rumble pack can
grouly925 is offline   Reply With Quote
Old 01-08-2008, 07:39 PM   #3 (permalink)
Ditch hopper
2nd Assistant Highjacker
Ditch hopper's Avatar
you could build a drop bracket for the rear suspion?
Real men Hijack threads
-1995 zr580- aaen pipe, epi clutch kit, camoplast ripsaw/120studs, 3inch riser, flybars, upgraded foxshocks, weisco pistons, lightly ported, 19tooth top 32thooth bottom soon to come bored carbs, plastic skis, new helix and ramps BRAAAP
Ditch hopper is offline   Reply With Quote
Old 01-08-2008, 08:56 PM   #4 (permalink)
kccats
Your springs could be getting weak? There are several ways to adjust the stiffness! More preload, move the bottom rear link, add the coupler set up!
