Zr600 Efi
I have a 2002 ZR600 EFI that runs great when cold. After it warms up the low RPM range starts to sputter. If you get the RPM above 6,000 it goes great. If you let it run long enough the servo will open and close at idle like it is quivering. Per the service manual the servo should not open until 6,000 rpm. I have cleaned the power valves, adjusted cable lengths. I have two of these sleds so I swapped the computer and servo with no change. The LED doesn’t give an error code. Any ideas on where to go next?
