Originally Posted by smallengineguy
Should be a bunch on the rear skid, The bottom of the steering shaft, the ski shafts that go up through the trailing arms.
Two on each upper and lower ball joint (SEG, the cat has A-arms), one each on the upper mounts of the rear skid, one each on the lower end of the same arms and in the back one, there should be one in the scissors arm. (so, at least 5 in the skid)
