2000 Touring Triple 600 starting
I'm helping my buddy work on this machine, and are having some problems......
First problem: Hard to pull start. It is incredibly hard to pull when cold; I mean like no other sled I've pull-started before (a good 4x as hard as you'd expect). After a few pulls, it does seem to loosen up a little bit, and you can actually finally get it started. Once the sled is warmed up, it can be re-started with a more "normal" amount of force on the pull. Any ideas what this could be? I can't believe this is anywhere close to normal.....but couldn't guess what could cause it to be so hard to pull when cold.
Second question: The Sled does have elec start.....but doesn't work. We've checked the intire path, and even used jumper-cables to go straight from battery (yes, it's charged and good) to the starter itself, and it doesn't even try to turn or engage. We began to start pulling the starter motor out of the sled, but it looks like you have to pull the entire motor and plate out to get to it. The starting motor itself is on the chain-case side of the motor, with a ~18" shaft going along the front of the motor to get to the gear/flywheel, and everything is mounted in such a way that it looks like you need to pull everything out to get at it. Has anyone worked on these before, and am I missing an easy way to pull the starter motor?
As always, thanks for the assistance.
