Old 01-06-2008, 08:56 PM   #1 (permalink)
catman1
Compression Questions
My 2005 sabercat 500 has 4000 miles and it has 115 psi in each cylinder, and i was wondering if that is good or not, or time for a new top end
catman1 is offline   Reply With Quote
Old 01-07-2008, 08:26 AM   #2 (permalink)
JDS
JDS's Avatar
Compression readings should be taken when the motor is up to temp. with the throttle side open. If yours were taken on a cold motor, they will be lower. Also, compression will sometimes read quite a bit lower at higher altitude. As long as your compression is close to the same for both cylinders and doesn't have any unusual noise, run it.
JD
____________
2001 Arctic Cat ZR500
1991 Arctic Cat EXT SP 550
1991 Honda Fourtrax
JDS is offline   Reply With Quote
Old 01-07-2008, 08:34 AM   #3 (permalink)
The correct way to get the reading is to pull both plugs, leave the ignition off, attach gauge, Hold throttle wide open and give a minimum of 3 pulls.
Old 01-07-2008, 08:38 AM   #4 (permalink)
kccats
I usually will give it 6-10 pulls! If indeed this is how you came up with it then yes it is time to freshen the motor! I ususaly tell people about 3500 it's about time! At 400 you may want pistons too!
