Old 01-06-2008, 09:57 AM   #1 (permalink)
wobawoba969
wobawoba969's Avatar
Can i use regular arctic cat mineral oil in my 2005 sabercat 500
i was wondering if i can use the regular arctic cat mineral oil or if i have to buy oil cuz ive got a jug of the regular stuff already.
1997 formula sl 500 fan
2005 sabercat 500
powermadd 2 inch bar riser
wobawoba969 is offline   Reply With Quote
Old 01-06-2008, 10:57 AM   #2 (permalink)
JDS
JDS's Avatar
If it's new under warranty, run what your manual says to run. If it's not under warranty, you can run whatever type oil you want. Mineral Oil is fine in that engine, but I would make sure that it it compatible with what is currently in your tank.
If the tank has synthetic in it, I would not add mineral to it. I would run it till you had very little oil left in it, suck the rest out and then fill it back up with the mineral oil. The alternative is to suck some of the oil out of the tank, and add some of your mineral oil to that oil in a clear jar and see if they are compatible. If they separate, do not mix them in your oil tank.
JD
____________
2001 Arctic Cat ZR500
1991 Arctic Cat EXT SP 550
1991 Honda Fourtrax
JDS is offline   Reply With Quote
