Old 11-11-2007, 03:35 PM   #1 (permalink)
coloradoman25
coloradoman25's Avatar
Sled slips from Forward into reverse wont stay in forward
1995 Wildcat 700 touring. Any idea what it would cost to fix this. I am told it is something in the gearing. This is a sled I am looking at. Its a sick deal I just want to know maybe what I am getting in to.
It does run and will work but has issues sometimes after reverse is used.
I was told by the seller its about a 400$ fix. What is involved? I am pretty mechanically inclined if its not a nightmare job. Just wondering if anyone has dealt with this.
Can I just permanentaly set it in forward for this season? Any help is appreciated,
Thanks
Chris
Co Springs Co
1999 Powder Special 700 1500 miles
1999 Powder Special RIP
2003.5 Mountain Cat 900 Mod Sled
1998ish zr600 In the mad scientists garage getting some new guts and mods...Should be interestin.
coloradoman25 is offline   Reply With Quote
Old 11-11-2007, 04:28 PM   #2 (permalink)
paintballdude05
1st Assistant Highjacker
paintballdude05's Avatar
I kind of had the same problem, forward would not engage but reverse was ok. It all started out after I did some hard accelerations from a stop to full out trying to get my sled to lift the skis, went home and after that it was toast. By the way i got a '96 ext 580 efi, would not be surprised to see the same chaincase. So I thought it might be the linkages that where off but that wasn’t it. Tore it apart and found that the shaft that has the sprockets on it for the track, drive shaft i guess its called, the splines @ the end where twisted about 1/8" out of its original location. I'm theorizing that this caused one of the hafts inside to rub a part and so on.... its hard to explain. The shaft is probably in the range on 100$, then you got to get some sprockets put on it, probably replace the bearings since you're in there, almost 100%, inner chaincase parts about 50$ give or take. You could probably do it for cheaper if you look on eBay like I did and go to a "bearing place" to get the bearings(got one of theme there the other one was only AC that could get it, and they where all top of the line Fafinir OEM). You should also get the shop manual for the sled that will help alot. It could be something big or something small; you just got to open it up to find out. Sorry about long post.
Old 11-13-2007, 09:10 AM   #3 (permalink)
kccats
Ther reverse is easy to remove and inexpecive to get stock gears and chain!
Old 11-13-2007, 10:57 AM   #4 (permalink)
paintballdude05
Yeah the chain and sprokets are not to bad but when you get into shafts and all the small parts this is where the repair gets expensive.
