Old 11-06-2007, 06:58 PM   #1 (permalink)
coloradoman25
coloradoman25's Avatar
Make my cat faster!
Any free cheap or reasonable mods I can do to my 95 zr700 to make it faster....I have only driven it from the driveway to the garage and couldnt keep the skis on the ground but i need something to mess with
Co Springs Co
1999 Powder Special 700 1500 miles
1999 Powder Special RIP
2003.5 Mountain Cat 900 Mod Sled
1998ish zr600 In the mad scientists garage getting some new guts and mods...Should be interestin.
coloradoman25 is offline   Reply With Quote
Old 11-07-2007, 08:15 AM   #2 (permalink)
kccats
Ther are ALOT that can be done! Start with the clutchs, air box, carbs, pipes, can, studs and then get into the motor! Where do you want to start?
Old 11-07-2007, 08:24 AM   #3 (permalink)
tamacat
Try to catch my CAT
tamacat's Avatar
Reeds for throttle response.
ARCTIC CAT
Worthington Flip Top Trailer
Old 11-07-2007, 04:33 PM   #4 (permalink)
JheLrey
JheLrey's Avatar
Loose Weight! Haha! JK!
Old 11-07-2007, 05:43 PM   #5 (permalink)
IndianRvrShiver
IndianRvrShiver's Avatar
Sounds like it's plenty fast, already!! To keep yourself busy, why not go through everything to make sure it is reliable (clutches, belt, hyfax's, bogie wheels, skid frame pivot points, etc). Look for stuff that could let you down out on the trail. It's a lot more fun to work on them in your garage in nice weather rather than on the trail when it's dark & -10*
Old 11-07-2007, 06:00 PM   #6 (permalink)
jKsled
Sconnie
jKsled's Avatar
tell him (and me) some more about reeds please?
~If you dont think it's bad @zz, then whats the point?~
1990 Skidoo Formula MX 470
1986 Ford Ranger 2.9L 4x4
3"body lift
3" Skyjacker suspension lift
dual custom exhaust
Old 11-07-2007, 09:00 PM   #7 (permalink)
ac bigbore
ac bigbore's Avatar
Cylinder reeds on this motor
Boyeson dual stage reeds are about all that is available aftermarket for this motor, as far as I could find when I mod'd mine. The reeds are not very large on this motor, and in my
opinion leave little room for improvement. I use them in both
of my 700-790 Wiseco bigbore motors. Don't know how much an improvement they are, but they are inexpensive (about 40 bucks)
so I use them.
As an aside, cylinder reed engines have been kind of poo- poo-d
in the past as not much better than piston port motors, but PSI
Racing has fairly recently come out with a cylinder reed top end and they point to some reasons why they have some unique advantages.
ac bigbore is offline   Reply With Quote
Old 11-07-2007, 09:04 PM   #8 (permalink)
jKsled
Sconnie
jKsled's Avatar
yeah, but what exactly are the reeds? where do they go
3"body lift
dual custom exhaust
Old 11-08-2007, 12:11 AM   #9 (permalink)
Reeds go between the carb and the base of the engine. They act as a one way valve so that when the piston is on the down stroke, the gas mixture is forced up to the top of the piston rather than some being spit back through the carb.
This allows the smaller cc engines to produce more HP and have a crisper throttle response.
Old 11-08-2007, 12:19 AM   #10 (permalink)
coloradoman25
I have en EFI though??
Co Springs Co
Old 11-08-2007, 12:25 AM   #11 (permalink)
So do I, and mine has reeds in it too.
Look yours up here:
' + objMainFrame.arrApplicationTitle['EN'] + ' -- EMPARTweb*Version 5.2.2* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * *
Arctic Cat E-Parts Catalogs -- EMPARTweb Version 5.2.2
Old 11-08-2007, 08:16 AM   #12 (permalink)
kccats
The old Wild Cat motor has a very small set of reeds, that are mounted from under the cyl! I put the boyseens in mine and I supose they helped? The only thing is you have to pull the jugs off to get at them! But while you're in there great time for some porting!!!
Old 11-09-2007, 02:12 PM   #13 (permalink)
jKsled
Sconnie
jKsled's Avatar
where would you buy the reeds from and how would you install them?
3"body lift
dual custom exhaust
Old 11-09-2007, 02:23 PM   #14 (permalink)
coloradoman25
For the record my sled has 946 miles on it...Its been gone through its reliable but I do appreciate and know the pain of trail repairs.
Co Springs Co
Old 11-10-2007, 07:56 AM   #15 (permalink)
dave.s3693
ARCTIC CAT
dave.s3693's Avatar
Well if you really want more speed and power, follow KCCATS advice. Try Buy ATV Parts, Motorcycle Parts, Snowmobile Parts, and Watersports Parts, Accessories & Apparel @ Shade Tree Powersports J R Graham, Powersports Warehouse Hot Seat Performance
There are plenty more but i can't think of them
dave.s3693 is offline   Reply With Quote
Old 11-10-2007, 01:03 PM   #16 (permalink)
Replacing reeds will not make a huge difference unless they are damaged or not closing completely.
A properly tuned drive train will make a bigger difference in the speed you get and reduce the loss of power due to worn, too tight, or mis-aligned components.
So, tune and clean the clutches, make sure that all the bearings are in good shape and well lubed. Check that the track is set at the minimum proper tension and is aligned properly.
Old 11-10-2007, 03:44 PM   #17 (permalink)
00ranger
always thought the 700s were piston port hence no reeds?
00ranger is offline   Reply With Quote
Old 11-10-2007, 03:56 PM   #18 (permalink)
ac bigbore
ac bigbore's Avatar
Kind of like a hybrid between piston port and reed.
The carbs attach directly to the cylinders and shoot
mix directly into the cylinders like piston port motors, but have reeds at the bottom of the cylinders that cover the transfer ports, or at least a couple of the transfers.
Old 11-13-2007, 09:26 AM   #19 (permalink)
kccats
The reeds cover the side transfere ports, the rears are open. This why they are open to large HP gains in porting! I have a ported( amond other Mods) 88, It is the fastest year of that engine which spans into 2000! Most only make about 115hp Im at about 140.It's a good stong debendable motor, just not up todays twins!
Open up the transfere ports and knife edge them, get a set of Boyseens, Have the carbs bored to 42's, add the air intake doors, get a set of black magic pipes, mill .030 off the heads, add 5 grams to the clutch and put atleast a yellow green spring in the drive clutch and give it a try.
Old 11-13-2007, 12:37 PM   #20 (permalink)
00ranger
a little wary of milling heads...milled my 580 by a known arctic cat performance shop.. turned out to be the root cause why it blew up 3 times...
You may not post attachments</
