Old 10-29-2007, 06:29 PM   #1 (permalink)
h2o addict
580 PS clutch question
I just got into snowmobiling last year and so far im having a blast. I started my 1997 580 powder special this weekend and noticed that the track was spinning at idle. I would hit the brake and stop it but as soon as it was released the track would spin again at probably 2-3mph. Should I take it in and get the clutch serviced?
h2o addict is offline   Reply With Quote
Old 10-29-2007, 06:35 PM   #2 (permalink)
BC_Dan
Start by just cleaning the clutch, start with compressed air and blow everything out.. that in itself may make a difference. The track will usually turn when the sled is up on a stand, as long as it doesn't creep forward when it's on the ground, you should be ok.. That's not saying the clutch doesn't need work, but a properly operating system will turn the track on a stand...
Rebuilding the fleet!
Old 10-29-2007, 06:40 PM   #3 (permalink)
h2o addict
Thanks for the reply. My vmax dosnt budge at idle so I thought this may be a problem. Thanks again.
Old 10-29-2007, 07:49 PM   #4 (permalink)
paintballdude05
1st Assistant Highjacker
paintballdude05's Avatar
Yeam my '96 ext 580 does the same while on the stands, not on the ground thought.
Old 10-29-2007, 10:23 PM   #5 (permalink)
Most sleds will do that when they are up on stands when they have a good belt on them.
Every sled I have ever owned would do that, and it made no difference as to the brand.
Old 10-30-2007, 09:16 AM   #6 (permalink)
kccats
Your Vmax may be the one that might need alittle help? See how hard it is to turn the track by hand and compare it to the A/C?
