10-29-2007, 09:34 AM
Motor swap 1996 550 Cougar
Hi, I am new to your forum and this is my first post.
I am looking to replace the motor is my sisters 1996 Artic Cat 550 cougar. I have located a couple of good used motors but neither is a 550. One is a 580 out of a 1996 ZR and the other is a 440 out of a 1994 ZR. Of these two engines, which one if either would be the most straight forward transplant (eg. motor mounts, wiring etc). I thank you in advance for your help and cooperation.
Regards, Muchco
10-29-2007, 10:05 AM
Try to catch my CAT
I would think the 580 would be the better fit of the two.
ARCTIC CAT
Worthington Flip Top Trailer
10-29-2007, 10:32 AM
Thanks for the response, I'm to the understanding that I can use the igntion components from the current engine. This being the case the wiring should not be an issue. It's also been suggested that I should use the exhaust from the 580 for sure. I have been told that I could get away with the 550 carbs with a little tuning but the 40mm carbs off the 580 would be better. Any additional thoughts?
Regards, Maury
10-29-2007, 05:41 PM
Get anything you possible can that came wit hthe 580. The more parts that go with it, the better off you are.
10-29-2007, 08:20 PM
Thanks very much for the response.
10-30-2007, 09:27 AM
First welcome to the snow show! The 580 is a very good engine, but it would only have 38mm carbs and I'm not sure the ignition or the electrical is the same? I would use the stator, flywheel and the cdi out of the 580 as well as the pipe!
10-30-2007, 09:33 AM
Thanks for the welcome and information. I have been told by the person selling the motor that the stator, flywheel and cdi are the same on the 550 and 580. Can anyone verify this for sure? I could get these parts with the motor but don't want to buy them if the ones I have off the 550 will work. If I make the swap I can get the 580 exhaust. The 580 was an EFI therefore I would have to go with the 36mm carbs for now.
10-30-2007, 11:34 AM
If the 580 is and EFI. get everything (wiring harness and ECU) and keep it EFI. It will perform better that way.
10-30-2007, 11:39 AM
That was my thought but the EFI components have already been sold. Thanks for the response.
10-30-2007, 02:37 PM
Brown's Leisure World - Home Page has online microfiche with part numbers you can look up.
10-30-2007, 05:36 PM
10-30-2007, 05:40 PM
Thanks for the information.
