Old 10-24-2007, 04:29 PM   #1 (permalink)
FoxLakeRider
The Man
FoxLakeRider's Avatar
580 Z 580zr
I would like to know the difference if any in these two model for exhaust reasons I have decided to buy one cause snow is a comin and my bike shop to busy for me to make one at this time ........ The OEM for 93 580Z is 0712-076 and for 93 580ZR is Oem 0712-081 The 076 seems to be much more expensive and some searches say 081 will work on my 93 580Z will either one work or....
FoxLakeRider is offline   Reply With Quote
Old 10-24-2007, 08:34 PM   #2 (permalink)
kccats
Whoa 93 580 Z, if memory serves me right the Z is a race sled, like a snopro? Do you own the Z?
And building an exhaust system for a high performance two stroke is not something a bike shop would likely be qualified to do. I know some engine builders that wouldn't dream of building there own pipes!
Old 10-24-2007, 09:13 PM   #3 (permalink)
FoxLakeRider
The Man
Yeah it a 93 580z and i dont want to mess it up so i will stick to my killa twisted bike pipes but still need to no for sure if the Z and ZR are interchangeable???
Old 10-24-2007, 11:51 PM   #4 (permalink)
FoxLakeRider
The Man
580z OEM
So i looked it up in a microfiche Thanks to Alssnowmobile and it shows 2 different pipes and muffler silencer for the 580Z was $260 for the 580ZR was $90 ??? so can i use the ZR style and mod to work or?? The one big diff i noticed was the muff silencer inlet ports were opposite 580Z to rear 580ZR to front
Old 10-25-2007, 10:30 AM   #5 (permalink)
kccats
There will be several small differences, mostly in performance. I'm not saying that the zr pipe won't work, but is there any pictures of both? You could get the zr pipe and compare them as long as it's possible to exchange them for the others if they are indeed alot different! The difference in pipes can make as much as 10-15 hp difference!
Old 10-25-2007, 11:53 AM   #6 (permalink)
IndianRvrShiver
IndianRvrShiver's Avatar
According to Alpha Sports - Arctic Cat Snowmobile Catalog The engines share the same p/n. The cylinders also share the same p/n. Didn't see any diffs in the mounting/outlet of the pipes. Don't know why the price delta. The listing implies the Z is available only with the EXT sled & has electric start (available) so I doubt it is a race version. JMO
Old 10-25-2007, 05:20 PM   #7 (permalink)
paintballdude05
1st Assistant Highjacker
paintballdude05's Avatar
I got a pic of my pipe that I posted. Its from a '96 580 EFI and it could possibly be interchangable and maybe cheaper.
Old 10-25-2007, 06:29 PM   #8 (permalink)
FoxLakeRider
The Man
The muffler can
The can on my 580Z has an inlet that is on the back edge of it and the 580zr inlet is on front edge according to the pics from Alssnowmobile.com and Pball dude your pic shows same can i have but yours is turned 90 degrees from what mine is but I think it would work or close and i can mod to fit. 245- 260 is a bunch for a stock pipe on older sled. The z and zr have same motor and manifold etc so i can see it robbing power or performance if i go with the 90 dollar one for the zr correct???
Old 10-25-2007, 07:05 PM   #9 (permalink)
kccats
Like I said give it a try, line them up side by side and look at what is different? You likly will be able to rework your can to make it fit, rotate maybe?
Old 10-25-2007, 07:20 PM   #10 (permalink)
FoxLakeRider
The Man
That what I figured too It should work with a little finess Ha Ha
Old 10-25-2007, 07:51 PM   #11 (permalink)
kccats
So what is wrong with your pipe? Have you tied to find an after market single pipe? Like Black Magic, Psi, D&D?
Old 10-25-2007, 08:45 PM   #12 (permalink)
FoxLakeRider
The Man
It is rusted and getting worse It could be patched I know but I would like a new one and patch this one for back up. and it is dented from last time crashed it... Dam railroad tracks anyway do you or some one have web address for a few places Ive checked a couple and noone seems to have a single for it that I have seen
Old 10-25-2007, 08:50 PM   #13 (permalink)
paintballdude05
I check a site up here in canada and it was something like 400$ lol
Old 10-25-2007, 08:53 PM   #14 (permalink)
FoxLakeRider
The Man
ouch thats quite a bit for that old sled...
Old 10-25-2007, 10:02 PM   #15 (permalink)
paintballdude05
Yeah I dont think they have adjusted they pricing and stock since the CDN dolar has been so hight.
Old 10-25-2007, 11:46 PM   #16 (permalink)
FoxLakeRider
The Man
Paintball i checked and the pipe for your 96 would be about right fit but the price was 285 dam
I dont understand how a pipe for my 93 580Z can be 290 and the one for 93 580zr only 90 same motor same manifold what the heck.... Im thinkin i can use the zr pipe and turn my can aroundto line up ports??
Old 10-26-2007, 10:24 AM   #17 (permalink)
IndianRvrShiver
FLR....check this link....guy parting out a ZR580.
HCS Snowmobile Forums
Old 10-27-2007, 08:14 AM   #18 (permalink)
kccats
I still think that the Z is going to be a bit of a higher performance! Perhaps it's the first of the triple exauhst port 580's! If so then yah the 95 would work and if you could get a used one with the can you would be set! I wonder if I still have a spare?
Old 10-27-2007, 08:34 AM   #19 (permalink)
IndianRvrShiver
Originally Posted by kccats
I still think that the Z is going to be a bit of a higher performance! .......
How could it be "higher performance" if p/n for engines & cylinders is the same??
Old 10-27-2007, 08:35 AM   #20 (permalink)
Exact same engine, the differences are in the suspension and drive train (clutching and gearing).
