10-18-2007, 05:44 AM
ITS NOT FAST WO MIXED GAS
handlebar risers
i want to put 2" risers on my zr 580. is it easy? and all i need to buy is the riser block right?
10-18-2007, 11:12 AM
For a 2" rise, you should be fine re-routing the brake line and the throttle/oil pump cable. If you go higher, you may have to get extensions or buy new cables to accomodate the height of the riser.
Rebuilding the fleet!
10-18-2007, 11:37 AM
do i just move the cables? i dont have to do anything serious do i?
10-18-2007, 05:13 PM
I'm not really sure, I sold both my zr's last year so I don't have one to look at. From what I remember of the bars, there was a little freeplay in the throttle and a little in the brake line. If you look at how things are layed out from the brake to the brake lever and the where the throttle/oil cables are routed, you should get a little free play. You can test it by taking the bars off, putting a 2" wood block in the space, and strapping the bar down to the wood. Then turn the bars to see if you have any tension anywhere. If so, longer cables or extensions are in order. You may have to re-route lines or clip some of the ties that hold things down to get the play you need. It's important to have some play, otherwise when you turn the sled, the engine revs when the cable gets tension on it.
10-19-2007, 02:21 AM
allright im gonna try it. it should work. thanks
10-19-2007, 05:27 PM
Braaaaaaaaap
If your cables are long enough, all you have to do is unbolt the old riser put the new one in and bolt back up!
2008 Cat 600 mod
2005 F7 SnoPro Team Edition! D&D Monster Single Pipe, BMP Valve Spacers, ODS Clutch Kit, Shaved Secondary (by ODS), 153 StudBoys, 8'' riser, Fly Bars/Hooks, Flyscreen, Acerbis Handguards, Black Lens Covers--FOR SALE
2005 Renegade 600 H.O.-Dads
10-19-2007, 05:29 PM
2nd Assistant Highjacker
I put the 2" risers on my zr580 and i didnt change a thing just have to move them around and zip tie them!
Real men Hijack threads
-1995 zr580- aaen pipe, epi clutch kit, camoplast ripsaw/120studs, 3inch riser, flybars, upgraded foxshocks, weisco pistons, lightly ported, 19tooth top 32thooth bottom  soon to come bored carbs, plastic skis, new helix and ramps  BRAAAP
10-20-2007, 01:54 AM
ok cool, i just ordered them. does it make much of a difference?
