Old 10-15-2007, 10:44 PM   #1 (permalink)
wyopowderspec
1996 powder special pipes and clutch
i just got a set of psi pipes for my sled and was wondering if anyone knew how prone my sled might be to becoming to lean at changing altitudes and blowing up? its carberated too. i was also wondering if anywon knew how well the six tower clutches that came on them usualy work and last? thanks for your time.
wyopowderspec is offline   Reply With Quote
Old 10-15-2007, 11:35 PM   #2 (permalink)
kccats
You will need to start with a base line for calibrating the jetting, Ask for a jetting and clutching chart for your pipes! There are some things you can add like the (I can't remember the name off hand)automatic altitude adjuster that will lean your carbs as you go up in alt, by float bowel presure.
