Old 02-19-2003, 08:28 PM   #1 (permalink)
MacCat
Question ZR600 efi Question
Just recently purchased a used 98 zr600 efi. Drained the old gas, replaced the spark plugs. Sled is hesitant out of the hole. Do you have to take it to a repair shop to determine if the efi is working correctly?
thanks
MacCat is offline   Reply With Quote
Old 02-20-2003, 06:20 AM   #2 (permalink)
catlover
catlover's Avatar
To check efi yes.But I would try some injector cleaner first.Maybe its been sitting for awhile and as gummed up .Good luck
catlover is offline   Reply With Quote
Old 02-20-2003, 12:05 PM   #3 (permalink)
Administrator
Sledder
Administrator's Avatar
Re: ZR600 efi Question
thanks
You will need to take it to a cat dealer. They have a computer linkage that they use to tune and test the EFI system. I have noticed that on really warm days, my EFI does bog a little bit, but at any temperature below about 25 it runs absolutely beautifully thorugh the entire speed range.
BUG THREAD - Report Bugs here
Old 02-24-2003, 06:38 PM   #4 (permalink)
1000ml
you can check the efi for codes at home depending on what style it is. the earlier models had a LED that would flash out trouble codes .not sure if your machine has it or not, if so it will be on/in the computer but visible from the outside(hood up)
1000ml is offline   Reply With Quote
Old 03-06-2003, 07:54 PM   #5 (permalink)
MacCat
It does have the LED on the bottom. Any idea how to initiate the diagnosis?
Is there somewhere I can find what the codes translate to?
Thanks
