Temp prob 4" vs. 10" What temp range is good at 10"
Ok, I origanaly put my temp probs 100mm from the piston skirt.
And I was told that 1115 degrees is good and 1200-1250 is bad.
Now, I have called AAEN and EGT (the place where I purchased the Pyro and probs.) They both say 10" from the cylender wall. Now, moving them is easy, they were the clamp on, and I can weld the old hole up very easy. My question is at 10" from the cylynder wall will these specs of 1115 degrees good and 1200-1250 bad still apply? Or will that change since the distence is much further from the piston skirt. At 100mm I was getting high temps just doing 40mph. Thats why I checked with EGT & AAEN. I thought the probs must be too close.
