Old 01-26-2004, 12:05 PM   #1 (permalink)
bly123
Sled Boggs between 5000 & 7000 RPM
Ok you probably don't know my setup so I will tell you that first. It's a ZR600 EFI With AAEN twinn pipes, D&D Trial Chip, and Boysen Raceing reeds with a manually ajustable fuel pressure regulator. I just got back from my weekend sled trip and found that although the engine ran very well I have a bad bogging between 5000 and 7000 rpm. So bad that I have to feather the throtle to get it past that rpm range. I can't seen to tune it out. What could it be?
bly123 is offline   Reply With Quote
Old 01-26-2004, 12:08 PM   #2 (permalink)
JoeyO
JoeyO's Avatar
APV check your power valve ports, make sure they are clean and not clogged. They open I think around that rpm, but not sure on what RPM exactly. I posted a thread asking what rpm they open but nobody replied yet
JoeyO is offline   Reply With Quote
Old 01-26-2004, 02:18 PM   #3 (permalink)
bly123
I don't have powervalves on this sled. Someone said the stator is bad. have you heard that before?
Old 01-26-2004, 05:22 PM   #4 (permalink)
joe_zrt
usually if the stator is bad it just won't get spark period. might be a cdi box or coil.
joe_zrt is offline   Reply With Quote
Old 01-26-2004, 06:28 PM   #5 (permalink)
dm7582
samething
I posted yesterday about a similair problem that I am having with my 580. Once it gets above 6000, but from 4800 til 6000 it just isn't right. I have pipes, chip and clutch kit also.
dm7582 is offline   Reply With Quote
Old 01-26-2004, 11:42 PM   #6 (permalink)
bly123
It sounds like you have the same problem. I have to start swaping out some of the performance parts to see witch one is causeing the problem. I think. I don't know. I was hopeing some one would have an answer on this forum.
Old 01-27-2004, 05:50 PM   #7 (permalink)
Holeshot King
I'd say check the throttle position sensor first.
Holeshot King is offline   Reply With Quote
Old 01-28-2004, 12:55 PM   #8 (permalink)
bly123
I have already unplugged my kill switch it was the problem of an earlyer bogg. But now I think I will replace the throttle position sensor to see if that is it. Would it make a difference in the middle of the power rang like that?
Old 01-28-2004, 03:24 PM   #9 (permalink)
Holeshot King
It can at times. I'd check the throttle over-ride first it could also be that!
