get a telescoping gauge and a mic, and measure both cylinders to see if the ID of the cylinder is the same. Measure both top and bottom. Get specs from dealer. That would be my suggestion on what to check. Oh...and make sure your base gasket is ok and that there is no break in it, cause just a little draft of air will lean out mixture.
