ok, i am gonna try letting the rpm's go down first and i will check the slide needle...is this the main jet when u talk about slide needles?
also, about clutching. my dad is running a 98 zl500 that hasn't been touched, it is bone stock but he had someone rebuild the clutch. Now his is much snappier than mine and seems to be revving higher too. What do te springs do if i change those as well as the weights? I don't really understand the parts involved with a clutch kit and what each part does, like the helix, weights and springs? can anyone explain?
