Old 12-09-2006, 01:33 PM   #1 (permalink)
CATZR440SNOPRO
CodyZR440sno-pro
Zrt 600??
I have a 1996 ZRT 600 Trip, i jsut bought the sled and it ran good for about 10 mins then the far right cylinder wont run untill its at about 5500 RPM, im not familiar with this sled, what would be rong with it? what was the deal with these sleds, open for anything there is to know about it thanks
CATZR440SNOPRO is offline   Reply With Quote
Old 12-09-2006, 01:54 PM   #2 (permalink)
jhickeynv
Race Ready
jhickeynv's Avatar
You fouled that plug. On mine I usally have to jet that hole 1 size leaner than the rest. To get it to run right you will just have to play with the jetting of all three holes depending on elevation.
jhickeynv
2007 Summit 800R
(just a can)
1999 ZRT 600 144" Mod sled (aka Green Headache)
Just sold 2005 Summit 800
2006 Haulmark 27' Enlcosed Trailer (Group Effort)
2002 Yamaha Raptor 660R
jhickeynv is offline   Reply With Quote
Old 12-09-2006, 02:25 PM   #3 (permalink)
tamacat
Try to catch my CAT
tamacat's Avatar
Are the carbs cleaned???
ARCTIC CAT
Worthington Flip Top Trailer
Old 01-04-2007, 01:10 AM   #4 (permalink)
TurboNorth
Could be a reed problem as well. Check your carbs and chokes. Does it do it with a new plug as well. Might be jetted to rich even. Is it hard starting when it is cold?
TurboNorth is offline   Reply With Quote
Old 01-04-2007, 07:06 AM   #5 (permalink)
tamacat
Try to catch my CAT
tamacat's Avatar
If it was the reeds though,that cyclider would no accelerate at all.Espesially higher rpms.I had the same problem with my 96ZRT. Make sure the carbs are cleaned well. What does the plug look like??
ARCTIC CAT
Old 01-04-2007, 01:19 PM   #6 (permalink)
nrg8
I had that with my middle cylinder, dumped old fuel, and removed cleaned carbs. It still was there but only at ilde, I touched the plug boot and it was firing I let go and the miss reappeared, pulled bood apart and condensation had corroded terminal end screw that screws into the wire, cut back till no green was seen and replaced boot (new), All was well
nrg8 is offline   Reply With Quote
