12-06-2006, 10:34 PM
Clueless on 79 Jag 3000 carb
Hello, Newbie here. I am currently stumped by a 79 Jag 3000 with a 340 spirit engine. It starts and idles great. As soon as I think about touching the throttle it bogs down. The sled sat for 2 years before I got it. I drained all fuel from tank. Replaced both inlet and output fuel lines including filter. I replaced the vacumm line from the engine which has good suction and just installed a new fuel pump. I dismantled the carb and blew out every hole and orafice that I could see. The spark is great and I just installed 2 new plugs. Any suggestions out there? I am stumped. I think that my next step will be to find a new carb. Thanks from the OHIO snowbelt. Go Bucks
12-06-2006, 10:51 PM
Plugs getting wet when you pull it over???
Any mouse nests in your air box?
2000 440 Panther
1980 Jag 3000 F/C
12-06-2006, 10:57 PM
I would assume that the plugs are getting wet. It idles fine. It just bogs down when I touch the throttle. As far as the air box goes, I removed it and cleaned all nuts and twigs before I ever thought of starting it. HMM....!
12-07-2006, 01:06 AM
Actually, did you use any carb cleaner?
You still have a plugged passage somewhere in there.
12-07-2006, 03:12 AM
Wants to see snow
As RJ said it sounds like a plugged carb. you may want to soak it in a container of carb cleaner. Then do the cleaning all over. Also check the Enrichner(choke) circuit it may not be closing down all the way.
84 srv 540 starting to mod
98 indy classic xlt 600
LET ME OUT OF THE HOUSE
12-07-2006, 02:11 PM
Choke stuck??? When it's idling, flip the choke on. Does it stall the engine, or do nothing?
2000 440 Panther
1980 Jag 3000 F/C
12-07-2006, 08:15 PM
Thank you everyone for the suggestions. I soaked the carb in chem dip for 1/2 hour, blew it out and reinstalled it. I still had the same problem with bogging as soon as I touched the throttle. I talked to a local mechanic and he said to check the switch located at the throttle. I checked it and sure as **** it was stuck and causing the engine to kill the rpms. Everything is running awesome and my son had the time of his life riding around. Thanks again to everyone for their help. We're expecting up to 10 more inches of snow tonight. Yippee.... See ya on the trails..
12-07-2006, 08:17 PM
12-08-2006, 12:20 AM
got the same sled and my son also loves blasting around on it. it is light and very quick. great for kids and girls. I also from northeast ohio. great to have some snow isnt it. bout time.
Enjoy Every Single Day
95' ZRT 800 mine
79' Jag 3000 F/C wife's
99' KX 250 mine
2002 Honda CR80 son's
12-26-2007, 10:05 AM
Scorpion Rider
I have the exact same sled that used to have the exact same problem except it would bog down and if you opened the throttle enough it would rev up. Once I got moving it would run fine. I took apart the carb 3 times and the third time I must have finally got the junk out, I fixed it! Before that I had tried 2 new sets of plugs and that didnt help at all. Hope this helps.
1971 ARCTIC CAT LYNX
1975 POLARIS COLT 340
1975 SCORPION LIL WHIP
1979 ARCTIC CAT JAG 3000
1980 SCORPION STING WITH A 79 STING HOOD
1980 SCORPION STING(NOT THE BEST CONDITION!)
1996 POLARIS INDY TRAIL
1997 POLARIS INDY TRAIL
1998 POLARIS INDY TRAIL TOURING
