Old 12-05-2006, 08:41 AM   #1 (permalink)
adingman99
Slow and a bit unwell....
adingman99's Avatar
1993 Mountain cat 580 idle
Hey everyone, your advice would be appreciated here. My sled has been running great, untill last night that is. When I come to a stop the idle gets very low, if i let off the break the sled starts to go foreward. It is like the clutch is still engaging even at idle. It was very hard to start if I shut it down. Now I can't seem to get it to start at all. At one point when I was pulling the starter the sled moved foreward on me as the motor turned over. Not very far or fast, but it did move about a foot or so. Any ideas on what I should check first. I am going to try taking the belt off tonight to see if it starts any easier. Thanks in advance!
adingman99 is offline   Reply With Quote
Old 12-05-2006, 10:51 AM   #2 (permalink)
tamacat
Try to catch my CAT
tamacat's Avatar
Broken clutch spring maybe??
Old 12-05-2006, 11:50 AM   #3 (permalink)
The primary clutch is probably jammed. check for broken spring or for bent/twisted/worn weights.
If the clutch has never been serviced, the weight bushings are most likely worn and one or more has gotten crooked and is binding. You will need to replace the bushings and pins at least.
Old 12-05-2006, 12:19 PM   #4 (permalink)
adingman99
adingman99's Avatar
Ok, also, how much side-to-side movement is acceptable on the secondary clutch (if any). Mine moves about 1/4 inch.
Old 12-05-2006, 12:21 PM   #5 (permalink)
Dennismc
Reverend Dennis
Dennismc's Avatar
that would prevent it from starting even? Ok learn something new.....
Dennismc is offline   Reply With Quote
Old 12-05-2006, 12:52 PM   #6 (permalink)
Yes to both of you.
Old 12-05-2006, 01:33 PM   #7 (permalink)
adingman99
adingman99's Avatar
Thanks for the advice. I will let you know what happened.
