i haven't found any leaks on the exhaust system..and i just put new spring, belt and shims on the clutch, thats why i doubt that was the problem, when its cool the clutch has no problem whatsoever engaging, its pretty quick out of the hole, but when i take a hard run down the street and turn around at the end where deeper snow is it just hesitates until i raise the hood, but like i said before the antifreeze is luke warm so i just wondered if that was part of the problem even though it needs to be looked at...why would it engage fine cold but not warm?
