Old 12-01-2006, 09:52 AM   #1 (permalink)
Outdoorsman
Sled advice needed
I just bought a 93' 580 EXT and the guy said that it hasn't been rode very much in the past couple years. Someone told me that I should stay light on the throttle for the first tank of gas. Do you guys think I need to do this? Thanks in advance.
Outdoorsman is offline   Reply With Quote
Old 12-01-2006, 10:14 AM   #2 (permalink)
tamacat
Try to catch my CAT
tamacat's Avatar
I never heard of that!!Maybe he thinks the motors all gummed up or something? However, maybe its not a bad idea.
Old 12-01-2006, 11:15 AM   #3 (permalink)
rgoers
rgoers's Avatar
HEavy on the gas would tend to clean the carbs better than going easy on it. Maybe he's thinking MECHANICAL problems (doesn't want it falling apart on you at 80 MPH).
2000 440 Panther
1980 Jag 3000 F/C
Old 12-01-2006, 12:17 PM   #4 (permalink)
SawBlade
give the carbs a good cleaning and change the gear case oil, then lube the entire sled. change out the old fuel with new fuel and the old injector oil. put new plugs in it and you should be good to go. pull the exhaust pipe on one cyclinder and check the piston the cylinder for carbon build up. If heavy carbon, you may consider cleaning or ring replacement.
Enjoy Every Single Day
95' ZRT 800 mine
79' Jag 3000 F/C wife's
99' KX 250 mine
2002 Honda CR80 son's
SawBlade is offline   Reply With Quote
Old 12-01-2006, 07:18 PM   #5 (permalink)
badbrad
saskatchewan sledder
badbrad's Avatar
i have not heard of this you are supposed to when you first get a bran new one but not for some thing like this
Whatever is written above is just my $.02
My family puts the "fun" back in dysFUNctional.
whoever said nothing is impossible, never tried slamming a revolving door
badbrad is offline   Reply With Quote
Old 12-01-2006, 07:30 PM   #6 (permalink)
upersleder
upersleder's Avatar
clean it up like sawblade said, put some sea foam in the first tank of fuel to clean the tank, lines and rest of the fuel system out and you should be good to go. i wouldnt pound it outta the box, just get used to it, but if everything is clean and working properly theres no reason you cant full throttle it
2003 MXZ 700X
Old 12-01-2006, 08:42 PM   #7 (permalink)
njk4o5
Arctic Cat Man
njk4o5's Avatar
if it hasnt been ridden for a while then you should just flip the throttle alot or just dont keep it at the same rpms for a loooooong time.
Ive never heard of going slow on a snowmobile though?
Arctic Cat FO' Lyffe
03' F7 Retro Snopro
01' Skidoo MXZ380f
98' Yamaha Vmax 500
02' Arctic Cat z370
njk4o5 is offline   Reply With Quote
Old 12-05-2006, 10:03 PM   #8 (permalink)
Outdoorsman
Thanks guys. I thought it sounded wierd when he said. I just wanted to make sure.
Old 12-06-2006, 09:29 PM   #9 (permalink)
Outdoorsman
Hi upersleder, where can you buy the sea foam and how much do you add for a tank of gas.
