11-28-2006, 10:43 PM
bog in my 600 efi crossfire
I have a 600 efi crossfire, just bought it, and took it out today for the first time, it has 700 miles on it.and everything looks as good as new. But it has a mid range bog in it. after it straightens itself out it goes like crazy. it is in the midrange to top end where it bogs.for just a second. do you need to lube the clutches on these??
I have read about the plug for blended and regular fuel as well could that do it?? or maybe could it be something else. any ideas guys too rich maybe???
thanks for now
Ken
11-29-2006, 08:40 AM
Try to catch my CAT
EFI box Problems maybe????
11-29-2006, 08:54 AM
cocky youngster
check the adjustment and function of your power valves. it sounds like they aren't opening correctly, but once open they are fine. kind of like they are hanging up. just my $.02.
Country Boys can survive.
2003 F7 EFI Limited Edition Sabrecat Graphics
1-3/8 sno pro track w/ 170 1.450 mega-bites
2.5 degree timing key
rumble pack can
11-29-2006, 09:46 PM
Had similar problem, but no top end at all. Found a broken cable and the other unattached to servo motor. Pulled both power valves for cleaning. Now just waiting for parts to see if that resolves problem. Frustrating huh?
11-29-2006, 10:16 PM
thanks for now
going to check the power valve idea first i,ll let you know what I find..
Ken
11-30-2006, 10:50 PM
I checked the power valves
I checked the power valves and cleaned them up they were sticky and I got a little better response but still bogs in mid range. I,m rumming ethanol fuel right now, and the the plug for the fuel (if it is a small blue plug on the ecm with 2 wires) is plugged in right now. Is this the right plug for ethanol or not??? does it make that big of a performance difference??? one other thing, how about the secondary clutch should the belt be flush with the top or should it be above????
11-30-2006, 11:01 PM
Belt "should" be just above secondary, but can't believe that would be the cause. My fuel plug is right next to the ECU, very visible. Does your servo motor cycle once when you start your sled? Just an unrelated question I had. You can check it with the cover off. Just wondering.
11-30-2006, 11:04 PM
i,ll check,, but that will be tommorow,thanks for your input
12-01-2006, 04:18 PM
If the power valves are ok, the only other thing to look at is the clutches. If they need cleaning, you will get a sluggish response too.
If the power valves are ok, the only other thing to look at is the clutches. If they need cleaning, you will get a sluggish responce too.
12-01-2006, 07:06 PM
saskatchewan sledder
Still having problems postin rj?
Whatever is written above is just my $.02
My family puts the "fun" back in dysFUNctional.
whoever said nothing is impossible, never tried slamming a revolving door
12-02-2006, 10:06 AM
yeah, the older version of Firefox was the problem. I upgraded to version 2.0 and don't seem to be having that problem now.
I like that this version also has built in spell check.
12-06-2006, 02:43 PM
I agree 100% thats all it can be!
12-20-2006, 10:24 PM
yes!! it is very simple ,,there is a clutch adjustment screw in the secondary under the deflection screw I turned it in to increase the engagement pressure works like a charm,,THANKS for your input people !!!!!
ken
