Old 11-28-2006, 08:29 AM   #1 (permalink)
skidoo kid 102
sundaypuncher 503
skidoo kid 102's Avatar
ethenol switch on firecat?
my friend has an 04'-05'? firecat 600. he says that it has an Ethenol switch on it. Does that mean you can run pure Ethenol in the sled insted of gas?
THE BEST THINGS IN LIFE GO BRAAAAAP!!!!!!
skidoo kid 102 is offline   Reply With Quote
Old 11-28-2006, 08:54 AM   #2 (permalink)
It means that he can use gas with ethanol blend. (E85)
Old 11-28-2006, 09:33 AM   #3 (permalink)
IndianRvrShiver
IndianRvrShiver's Avatar
Not E85 (85% Ethanol)! Just the 5-10% blend they often sell at the pump.
Old 11-28-2006, 09:49 AM   #4 (permalink)
PolarisINDY500
SENIOR MEMBER
PolarisINDY500's Avatar
^ im still confused....so what your referring to would be for premium gas...regular gas you dont need adjustments.
The Original Logo ->
Old 11-28-2006, 10:22 AM   #5 (permalink)
Wild child
POLARIS RULZ
Wild child's Avatar
My switchback has a premium switch on it. It is for when you are running higher octane fuel you can switch it to advance the timing to get the full use of the higher octane fuel. The only thing is that if you leave it on that setting it will cause motor damage if you run a low octane fuel
2005 Polaris Switchback 600ves
1998 Polaris XC600
Wild child is offline   Reply With Quote
Old 11-28-2006, 11:17 AM   #6 (permalink)
IndianRvrShiver
Ethanol can be added to both regular &/or premium pump gas....usually in small amounts (5-10%). The FC ethanol switch is used for that particular scenario. AC recommends regular unleaded (87 ROM) for their engines. As I understand, it affects fuel metering (richer) when the switch is activated; does not revise ignition timing.
Old 11-28-2006, 11:26 AM   #7 (permalink)
Wild child
POLARIS RULZ
Wild child's Avatar
The switch on my sled does adjust the timing on the sled for the fuel you're running
1998 Polaris XC600
Old 11-28-2006, 03:22 PM   #8 (permalink)
IndianRvrShiver
That's what you mentioned in your previous post! The original question was about an AC Firecat.
Old 11-28-2006, 05:47 PM   #9 (permalink)
Mongo
ZR 800
yeah, IRS is right - that 'switch' really controls fuel delivery. certainly a lot easier than jetting up a size for running on what they call 'oxygenated' (10% ethanol blend) fuel. has NOTHING to do with octane
Mongo is offline   Reply With Quote
