Old 11-26-2006, 02:47 PM   #1 (permalink)
richep
Belt problem
I have an 85 cougar that I put a new belt on. It seems to work fine through the rpm's, but when idling, it won't disengage. It's also hard to pull over. any ideas?
richep is offline   Reply With Quote
Old 11-26-2006, 03:41 PM   #2 (permalink)
Wild child
POLARIS RULZ
Wild child's Avatar
It sounds like you have to tight of a belt
2005 Polaris Switchback 600ves
1998 Polaris XC600
Wild child is offline   Reply With Quote
Old 11-26-2006, 03:41 PM   #3 (permalink)
poke74
mcmurraysmonster
poke74's Avatar
could be
just wondering if its a oem belt or aftermarket? i bought an aftermarketbelt for the pol that was "supposed" to be the right one . wasn`t it was to small and wouldn`t disengage .
07 crossfire 1000
98 xc 700 mod
TO THE BAR - LEAVE THE SNOWDUST FOR THE REST
poke74 is offline   Reply With Quote
Old 11-26-2006, 04:32 PM   #4 (permalink)
richep
It's an aftermarket.
Old 11-26-2006, 04:58 PM   #5 (permalink)
What brand is it?
Old 11-26-2006, 05:17 PM   #6 (permalink)
TUGHILLYAMMI
J. DRISCOLL
TUGHILLYAMMI's Avatar
I would start by making sure you have the right belt. It sounds too tight. I know everyone hates to pay dealers price but i might buy one from the dealer that way you know it the belt that the machine is called for then go from there.
TUGHILLYAMMI is offline   Reply With Quote
Old 11-26-2006, 08:55 PM   #7 (permalink)
Wild child
POLARIS RULZ
Wild child's Avatar
I had bought a belt from dennis kirk to save some cash and when i got it i compared it to my polaris belt and it turned out to be 1/2inch to short. I buy nothing but polaris belts now
1998 Polaris XC600
Old 11-26-2006, 09:21 PM   #8 (permalink)
ac bigbore
ac bigbore's Avatar
I had same problem on 92 wildcat. Turned out to be
a bad bushing on the primary clutch. It was the bushing
inside the movable sheve. The bushing slid part
way out and wouldn't allow the sheve to return to full rest
position- it would come to rest in a partly engaged position. Sled would move when pulling the cord, and needed brake to keep it stopped. This with a well worn correct belt. This started slowly while out on the trail- noticed when sled kept
moving after trying to come to stop.
Just one possibility.
ac bigbore is offline   Reply With Quote
Old 11-27-2006, 08:21 PM   #9 (permalink)
rgoers
rgoers's Avatar
Had a similar problem a while back. It turned out to be a busted weight! It was stuck in such a way that it wouldn't let the clutch open all the way.
2000 440 Panther
1980 Jag 3000 F/C
Old 11-27-2006, 08:49 PM   #10 (permalink)
Wild child
POLARIS RULZ
Wild child's Avatar
It's the belt it's to tight. If it was the clutch it would not run good thru the rpm's. My sled had the same problem from an after market belt. It was the wrong size
1998 Polaris XC600
Old 11-27-2006, 09:34 PM   #11 (permalink)
tcat20
after market belta are usualy close to the right size you just have to adjust the driven clutch you have to do this even with oem belts there never the same size
tcat20 is offline   Reply With Quote
Old 11-27-2006, 10:16 PM   #12 (permalink)
TUGHILLYAMMI
J. DRISCOLL
This is kinda off topic to your problem but you might wanna make sure your primary and secondary is aligned just while you are playing in the general area. If not so shim up clutch and align them. If not your might cease your crank. I KNOW FROM EXPERIENCE.
Old 11-27-2006, 10:58 PM   #13 (permalink)
sledhead67
i say you got the wrong belt i would buy and i do buy nothing but from the dealer them self from i had the same problem once i wont do it again. sry to hear you arent haven the luck.
sledhead67 is offline   Reply With Quote
Old 11-28-2006, 08:04 PM   #14 (permalink)
richep
How do I adjust the driven clutch?
Old 11-28-2006, 09:16 PM   #15 (permalink)
forrest_fire1
stumpfinder111111111
How long has it been since it has worked properly?
forrest_fire1 is offline   Reply With Quote
Old 11-28-2006, 10:39 PM   #16 (permalink)
Andy Rice
Rice Burner
if you have a comet clutch it could be sticking look at it see if its sticking lube it up or take it apart and find the problem
Andy Rice is offline   Reply With Quote
