In my 1995 manual...
To test the Throttle Position Sensor...
Use a multi-meter to test between the red adn black leads in the throttle sensor connector. Spec is 5000 ohms +/- 15 percent
Test btween the throttle sensor's black and white leads witht he throttle in the idle position. Test spec is 850 ohms +/- 15 percent
Test between the white and black leads with throttle wide open. Test spec is 5000 ohms +/- 15 percent
Attach the mulitmeter to the throttle sensor black and white leads; then compress and release the throttle lever. You should note the resistance changes. If the resistance does not change, the sensor is not operating correctly.
If the throttle sensor is faulty, replace the throttle sensor.
YOu cannot disconnect an EFI throttle sensor. It is required to send input to the ECU caluclation of fuel/air mixture ratio.
I think SEG is thinking of the Throttle position switches on a carb model, which are a PITA to set and can be disabled by jumping (which also defeats the safety feature; if the slides freeze open and the throttle is at idle, the engine dies. If the switch is bypassed, if the slides freeze open, HANG ON!)
Rebuilding the fleet!
