Here Goes.... I just got a 71 440 Arctic Cat Panther for free from some Old guy that used to own a Small Engine repair buisness. i know the guy and stop in a few times a year to see what he got... He gave me a snowmobile.. It is in good condition. no rips in the seat, not dents or cracks, track is in good shape. it was garadge kept, untill it was in a flood. needless to say it doesn't run. I have most of the engine torn down and I have found a full Rebuild kit for it, which i am getting. as i was disassembling the engine, i ran into some a fair amount of surface rust and losts of water, I have gotten all the water removed and most of the rust removed. On further inspection I noticed damage to the #2 cylinder and piston. so that is going to need replaced. along with fuel lines, and all the seals and gaskets. I have done some resurch on the net and have been unable to find much of anything except for rebuild kits and pistons. Here is what i got:
Part Number on the side of the snowmobile just under serial :0110-447
Engine: TIA440SI Displacement : 436cc
by: Kawasaki Heavy Industries LTD.
Carb : HD27A
I can't find any parts numbers for anything.. I have found parts numbers for the 73-75 version and i have noticed there is very little diffrence (if any) between these years and mine. The engine parts diagrams for the same make and model 73-75 look the same as the parts that I have... although i am not sure if they are the same...
The parts number for a 1973-1975 are (1) #3000-233 and (2) #3000-232
Ref :
Alpha Sports - Arctic Cat Snowmobile Catalog
Can anyone tell me if all or most of these parts are interchageable between years and if i can use these parts on a 1971? They all have pretty much the same parts numbers for the engines
Thanks ALOT!!
