before you go and spend your money are the cylinders wet by any chance? If they are that is probly your hissing sound. If you have the abiltiy pressure test the bottom end you will have to put your heads on first, but it is a lot cheaper. You can plug off one side of the motor and see if it holds air. Be sure to not go over 8 psi though or you might blow out a seal. good luck hope its a cheap fix for ya
own firecat 600, have owned 2003 440 sno pro, 1997 zrt 600, 1997 z 440, 1997 zr 440
