08-31-2006, 10:30 AM
Riser for Z370
Hello, i have a Z370 but the handlebars are too low for me to stand up straight. What is the maximum amount of riser i can fit on my sled before I need extentions, longer lines, cutting etc.
Thanks
08-31-2006, 11:09 AM
SENIOR MEMBER
not sure on your particular sled, however, mine was roughly 2". i just unbolted my handle bar and could see how much room i had. some ppl say you can get about a 4" riser before you need longer cables, ect.
one thing i also did was i called dennis kirk (the site where i bought the riser from) and asked what riser would fit on my sled w/o modifying the cables. and he said 2".
not sure how much help this is, but this should get you started.
The Original Logo ->
08-31-2006, 11:58 AM
Vroooooooom
i guess it would depend on the year, but i made myself a set of 3" risers out of aluminum on my 01. I still had plenty of slack. Here's a pic.
Horse power: If it doesn't scare you, you don't have enough
05 F7 carb
01 ZR800 LE - Sold, but loved her
95 EXT 580 - GONE
08-31-2006, 12:01 PM
Vroooooooom
sorry, here's the pic.
05 F7 carb
95 EXT 580 - GONE
08-31-2006, 12:02 PM
Vroooooooom
wow, never mind. It doesnt want to attach. Sorry mate
05 F7 carb
95 EXT 580 - GONE
08-31-2006, 05:08 PM
I've heard since the bars are at an angle it pushes them back when you put a riser on.Will it move it back alot?
08-31-2006, 07:44 PM
I put a 1" on my '00 ZL, and the cables are max'd out. A 2" wouldn't have fit without adding cable extenders.
2000 440 Panther
1980 Jag 3000 F/C
08-31-2006, 08:09 PM
SENIOR MEMBER
mine didnt move back that far, or for that matter none that i noticed.
i know you can get adjustable risers if that is a concern.
08-31-2006, 09:31 PM
Ok thanks, well when I pull it out of winter storage soon i will see. Ill just use wood blocks as an imitation to see how much rise I can get.
09-01-2006, 10:14 AM
Vroooooooom
The 00ZL is a different style than my old 01zr.
What year is your z370? Apparently, it may make a difference.
05 F7 carb
95 EXT 580 - GONE
09-01-2006, 11:44 AM
Its a 2002.
09-01-2006, 01:37 PM
Registered Snow-Offender
your dealer should also be able to tell you how high you can go, And like PI500 said you can get adjustable risers which I have on mine so I could go forward as well as up. The adjustable ones aren't as sturdy. I keep and allen wrench with me so I can tighten them when need be.
Ride Hard...complain later
09-01-2006, 09:21 PM
I'll call up Dennis Kirk tommorow as PI500 suggested. I dont suspect my local dealer will know about this because many dealers around here are pretty clueless about specs.
