Diamond drive interchangability - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 12 (permalink) Old 01-07-2017, 05:42 PM Thread Starter
Question Diamond drive interchangability
So the gearcase in my 2010 Crossfire 600 CF6 is done. I found a diamond drive from a 2009 M8. The 2009 M8 had electronic reverse. Will this gearcase fit into my Crossfire?
Palooza is offline
post #2 of 12 (permalink) Old 01-08-2017, 05:47 AM
Quoted: 143 Post(s)
Im not aware of a different DD than the 04?
But this is a good time to dump the DD!
Im not a fan of the DD! My newest Cat is my 04 Pantera with chain case!
kccats is offline
post #3 of 12 (permalink) Old 01-08-2017, 05:48 AM
Quoted: 143 Post(s)
Wait did the 10 have the plate that went over the driven clutch?
Is the drive shaft the same and the brake rotor?
kccats is offline
post #4 of 12 (permalink) Old 01-09-2017, 09:14 AM Thread Starter
not sure!
Palooza is offline
post #5 of 12 (permalink) Old 01-09-2017, 09:16 AM Thread Starter
someone told me that the 09 with electronic reverse will not work since the 2010 CF6 has mechanical reverse. Gearing in 2010 CF6 is 60/60, where the gearing in the 2009 M8 is 57/63. This will result in more bottom end power and less top end speed (I am told), which doesn't concern me.
Palooza is offline
post #6 of 12 (permalink) Old 01-11-2017, 07:38 AM
Quoted: 143 Post(s)
You can always change out the gears.
kccats is offline
post #7 of 12 (permalink) Old 01-11-2017, 12:23 PM Thread Starter
Good point.
I've since learned that the issue is mostly around the reverse, that pretty much any gearcase will fit and are interchangeable between arctic cat sleds, but you may end up with a different gear ratio (or you may no longer have reverse). The 2010 CF6 still has a mechanical reverse, where most of the sleds in arctic cat's lineup changed to electronic reverse in 2009 or so, so an older gearcase from a 2008 M1000 will work for my needs, for example.
Palooza is offline
post #8 of 12 (permalink) Old 01-12-2017, 05:53 AM
Quoted: 143 Post(s)
But have you looked into doing the chain case swap?
I almost bought an 05 ZR 900 efi, but couldn't get around the DD with no way to add rev!
kccats is offline
post #9 of 12 (permalink) Old 01-12-2017, 09:33 AM Thread Starter
Good idea, I wish I had thought of that, but the replacement DD is on it's way!
Palooza is offline
post #10 of 12 (permalink) Old 01-12-2017, 03:50 PM
Quoted: 143 Post(s)
So what happened to yours?
kccats is offline
post #11 of 12 (permalink) Old 01-12-2017, 03:54 PM Thread Starter
DD had a crack and lost oil, essentailly all parts damaged inside. I was also told if you dont change the oil every year to expect problems. This seems crazy that synthetic oil could break down that quickly.
Palooza is offline
post #12 of 12 (permalink) Old 01-12-2017, 03:55 PM Thread Starter
I don't like the design on the Arctic Cats (this is my first Arctic Cat sled), Doesn't make sense to add all that weight and complexity over a chain. What's the thinking with this design?
Palooza is offline
