My son knocked the track off of my 04 Arctic Cat Panterra. The track was off the rear idlers and jammed tight against one side of the tunnel. I was unable to get it back on as it was -30. Ended up strapping a couple of crazy carpets to the track and pulling it approx 2.5 miles. Dropped the suspension and got the track back on and aligned. Track tension set so that I had 2 inches with 20 lbs of weight as per manual. Drive sprocket feels tight and teeth look ok and appear to be aligned correctly. No visual suspension damage. All bolts are tight. Ran the track while on stand and looked good. Even on both sides. Took out for a ride and it ran great on the straights but on the bumps the track rubs momentarily. Thought it was track tension so continued to tighten track....small amounts and continued testing on the bumps. Tension increase did minimize the amount of rubbing but did not resolve it. Even with track so high it was vibrating. I took it in to a mechanic and he is stumped. He confirmed that it is not ratcheting. Cant find the problem even with machine on it's side. He thinks a rail may be bent but I would think it would rub continuously then. I was thinking of adjusting the front spring tighter on the suspension....but sled ran great prior to incident.
Thanks a bunch. How do I fix it? Do I have to drop the suspension again and raise the shock? I guess I must have moved it while I was wrestling the suspension back into place.
Yep.
Loose the track raise the back end.
Put a ratchet strap around the rear swing arm.
Drop the back of the suspension.
Loosen the strap a little, and you may be able to swing the shock up with a pry bar?
Inspect that nothing got bent!
Then hold the shock up and tighten the strap.
Lower the body down to meet the suspension, tighten or loosen strap to move the rear mount forward or back!
kccats hit the nail on the head. Bottom rear shock was flipped. I followed the instructions you guys gave me and the track rubbing issue is gone. MUCH APPRECIATED GUYS!!!
Related Threads
Snowmobile Forum
630.8K posts
58.1K members
Since 2002
