arctic cat won't start - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 12 (permalink) Old 01-04-2004, 06:20 PM Thread Starter
i have a 1976 arctic cat jag 3000,i'm not sure if the cold weather has an
effect or not. i tryed since friday up to
today trying to start my cat i have new plugs in it fresh gas but nothing
tomcat14 is offline
post #2 of 12 (permalink) Old 01-04-2004, 06:39 PM
are you getting spark
north is offline
post #3 of 12 (permalink) Old 01-04-2004, 06:47 PM Thread Starter
yep, she ran before.. the fuel line isn't frozen
tomcat14 is offline
post #4 of 12 (permalink) Old 01-07-2004, 10:42 PM
pull your plugs and pour a little(a couple dribbles) gas into the cylinders put the plugs back in and try it . if it fires up but wont stay running try spraying gas into the carb if it fires up but still wont stay running you most likely have a fuel delivery problem. either plugged up carb or fuel line or defective pump or pulse line
1000ml is offline
post #5 of 12 (permalink) Old 01-08-2004, 12:29 PM Thread Starter
arctic cat won't run
i poured gas where the plugs goes, nothing i have my neighbors
carb spray i'll try that
tomcat14 is offline
post #6 of 12 (permalink) Old 01-08-2004, 07:16 PM Thread Starter
1000 ml, i sprayed carb in to the carburator and nothing
tomcat14 is offline
post #7 of 12 (permalink) Old 01-08-2004, 07:47 PM
you have spark at the plug, you have gas still nothing
north is offline
post #8 of 12 (permalink) Old 01-08-2004, 08:03 PM Thread Starter
nothing north
tomcat14 is offline
post #9 of 12 (permalink) Old 01-19-2004, 06:33 PM
Check compression. prob isnt much there. If u have gas and spark it has to run unless there is a bad ring or seals.
zrtease is offline
post #10 of 12 (permalink) Old 01-19-2004, 06:38 PM
Cook and bottle washer
Faceman's Avatar
Won't go
UNLESS. Check the filter and as much as I hate to say it, you might try taking the gas line apart b4 the filter and sucking gas out of the tank. Then reconnect to the filter.
Faceman is offline
post #11 of 12 (permalink) Old 01-25-2004, 02:07 AM
sno-pro-666's Avatar
ok
are the plugs still dry after you pull on it
sno-pro-666 is offline
post #12 of 12 (permalink) Old 01-26-2004, 09:46 AM
it could be you cdi box they where very common problem in those sleds. I should know it's happen to me why i was ridding.
arctic cat boy is offline
