well that sounds like your sled is working backwords. when you changed your gearing you should of got more top speed the way you had it set up the first time. what is your tpo rpm and is that clutch kit made to work with those pipes, and did you jet the sled to wor with the pipes?????
own firecat 600, have owned 2003 440 sno pro, 1997 zrt 600, 1997 z 440, 1997 zr 440
