Old 01-29-2006, 10:52 PM   #1 (permalink)
speed demon
hard starting 440
i have noticed it doing this everytime i go to start it, it will start and then stall, so you have to keep reving it a little to keep it going. it does no matter if its warm or cold. after it warms up it will start in 1 pull though. also it seems to be really slugish when you pin it. could this be somthing simple like new plugs because they haven't been switched since last year and i fogged it for the summer.
speed demon is offline   Reply With Quote
Old 01-30-2006, 06:36 AM   #2 (permalink)
MOre likely dirty carbs. Remove and clean them.
Old 01-30-2006, 09:59 AM   #3 (permalink)
speed demon
k thanks
Old 01-30-2006, 09:59 AM   #4 (permalink)
speed demon
would carb cleaner work or no?
Old 01-30-2006, 02:11 PM   #5 (permalink)
No, disassemble them and do it right, so you only need to do it once.
Old 02-18-2006, 06:18 PM   #6 (permalink)
capristang
did you ever get your carbs cleaned? if so did it help your sled run any better? just wondering because my 87 eltigre 440 is doing the same thing. I have cleaned the carbs once this year and have actually changed one carb do to breaking with a new one.
capristang is offline   Reply With Quote
Old 02-19-2006, 07:42 AM   #7 (permalink)
speed demon
i got the carbs cleaned 2 years ago. then a year after it started acting up. i tryed carb cleaner and it didn't change anything. so ya carbs need to be cleaned again. but not too bad if they last a year.
should i change the fuel filter? maybe its letting more dirt in now.
Old 02-19-2006, 07:58 AM   #8 (permalink)
If it won't idle on it's own, the pilot jets in the carb are plugged. Disassemble and clean the carbs. Change the filter also, if it has one.
Old 02-19-2006, 09:35 PM   #9 (permalink)
letitsnow
I am the Walrus
letitsnow's Avatar
carb cleaner is virtually useless in my book, use compressed air and a needle to clean the jets.
My Pics
1999 Arctic Cat ZL 440
1994 SkiDoo Mach 1 583
1995 Honda CR 125R
1982 Camaro w/ 355
