ext preformance questions
hello all still playin around with the 94 ext here. i have a couple questions,
1. what is the proper peak engine rpm for this sled? on the average i am seeing about 7200 rpm max, this is on the side of a plowed road with ice on it. got whipped by a 96 mxz.
I replaced the gearing that was in this sled from 23 35 to 19 39 that helped alot, but when they redid this sled it was blessed with a 2000 zl roller secondary. then i also added a green white cat spring to the primary to bring engagment to 4200 rpm. I have a felling that possible my clutches might be shifting out to soon before the motor can carry the load, bein the motor runs top shelf just will not pull the rpm's. i was told that if i changed my wrap on the secondary that it would help this issue, but i am open to idea's. anyone have any? this sled is an 85 mph sled on the icy road and feel like it should do a touch more. thanks all in advance for the help
