Old 01-19-2006, 05:56 AM   #1 (permalink)
locky
Michigan Member
locky's Avatar
2000 Z440 Suspension help
Hey Guys, What shocks, springs or both should I put on my 2000 Z440? After riding last weekend in the U.P. I need to do something better to my suspension. Thanks!!
locky is offline   Reply With Quote
Old 01-19-2006, 10:40 PM   #2 (permalink)
sesnopro
four gear pinned
sesnopro's Avatar
im assuming you want a stiffer ride.
0704-890 SPRING,SUSPENSION-RH-PTD BLK
0704-891 SPRING,SUSPENSION-LH-PTD BLK
0704-472 SHOCK,REAR ARM-PIGGY BACK <fox resivor
-these are out of a 99 z sno pro.
http://www.hiperf.com/
Old 01-19-2006, 11:04 PM   #3 (permalink)
rgoers
rgoers's Avatar
Locky - I just put a Fox shock on my ZL. I just did the rear skid shock, and it makes a world of difference over the stock Ryde FX unit. The Fox kit runs about $189, with the correct bushings.
Springs will make it stiffer, but not a smoother ride. It's the shock that does the damping. If you want smooth, a weaker spring setting with a better shock will work wonders.
That is - unless you're out riding with that babe my ugly twin brother just married. In that case, you'd want heavy-duty springs!!!
2000 440 Panther
1980 Jag 3000 F/C
Old 01-20-2006, 07:17 AM   #4 (permalink)
SnowRida
Runnin Against The Wind!
SnowRida's Avatar
Actually, if you use a larger oil cap with a tether attached, it will make a world of difference in the suspension. Smoother ride, and will take the bumps better. You also might want to put a 1/2 in. rubber gasket under the oil cap for better dampning.
SnowRida
Yamaha V-Max
02 MXZ 600
97 Polaris Indy Trail Touring
Old 01-20-2006, 04:12 PM   #5 (permalink)
And don't forget, it must be properly wedged in somewhere.
Old 01-20-2006, 07:27 PM   #6 (permalink)
SnowRida
SnowRida's Avatar
Great advise! I love this this forum!
SnowRida
Yamaha V-Max
02 MXZ 600
