Internal coolant leak
I've got an '81 El Tigre with the 500CC liquid cooled engine. I got it for free becuase the previous owner had an internal coolant leak that filled the engine. He replaced the head gaskets, but the problem came back right away. Looking at the head gaskets, I think he botched the job. The head bolts weren't very tight (just a little more than finger tight) and there was some substance on them like uncured RTV.
Head gaskets are a given at this point but I'm wondering if I need to bother with base gaskets too. I have dried up the coolant passages in the cylinders, and I don't see any coolant passages connecting to the crank case. Someone please tell me if I'm right in thinking that base gaskets aren't a part of a coolant leak on this engine.
The motor seems to be in good shape other than this. Compression was 150 and 149 psi. Spark is nice and hot. Haven't started it yet for the obvious reason.
!981 El Tigre 6000
