Old 01-16-2006, 08:53 AM   #1 (permalink)
enrolb
clutch repairs
I was wondering how difficult it is to repair a clutch? My 1995 Pantera EFI 580 primary clutch sticks closed at full speed. Upon inspection there is three bushings worn where three arms slide against (sorry I don't know the real names). I see online there is a clutch kit available for repairs. I was wondering if special tools are required and what should I look for?
I also noticed that the clutch looks really dry yet the manual says no lubrication is required. What do you experienced riders do?
I have only had this sled for a few months.
TIA
1995 Pantera 580 efi
let it snow, let it snow!
enrolb is offline   Reply With Quote
Old 01-16-2006, 01:33 PM   #2 (permalink)
sesnopro
four gear pinned
sesnopro's Avatar
it is relativly easy, all you need to do is take off the weights and put in the new bushings. look over your weights also.
no grease is needed
im pretty sure that is what you need to know, right?
http://www.hiperf.com/
Old 01-16-2006, 05:28 PM   #3 (permalink)
Very easy. Just be careful with that spring when you remove the cover.
Old 01-17-2006, 08:46 AM   #4 (permalink)
enrolb
Sounds good! One more question. Do I need a puller or what do I use to get the clutch off the shaft? or is it keyed?
Old 01-17-2006, 10:35 AM   #5 (permalink)
You need a special puller, but if you can get the outside half off without having to remove the other half, just do that. Take out the big bolt on the end and slide the outer half off.
Old 01-20-2006, 09:08 PM   #6 (permalink)
enrolb
Thanks for the help so far.
I took some of the clutch apart and was able to change the cam arm bushing and pins but I also need to change the bushings #13 (on diagram) which I can't take out unless I can take the spider part off which seems to be threaded. Any ideas on how to remove it? I don't want to force to hard for fear of breaking something.
Old 01-20-2006, 09:44 PM   #7 (permalink)
rgoers
rgoers's Avatar
Looks like you're already into it... I was going to tell you that after taking the cover off a half dozen times myself - I read the manual and it tells how to change the weights by compressing the sheaves, and wedging them in that position. That takes the spring pressure off the weights, and they can be changed without taking the cover off.
Since you're already past that part... the manual tells you to pull the clutch to get at the spider. Then, there are special tools you'll need to take it off. You'll want to heat it with a torch first to loosen the lock-tite too. Are you sure the spider is worn? It looks like a pretty involved job...
Get a manual on CD from eBay. Mine ran me a whopping $10 delivered!
2000 440 Panther
1980 Jag 3000 F/C
Old 01-21-2006, 09:19 AM   #8 (permalink)
DitchPickle
Firecat Fanatic
DitchPickle's Avatar
Since it sounds like this is the first time you worked on a primary clutch, don't forget to put it back together with the alignment marks properly aligned. You may already know this, but I thought I'd share since nobody else chirped in.
2004 Firecat F6 EFI
DitchPickle is offline   Reply With Quote
Old 01-21-2006, 02:26 PM   #9 (permalink)
rgoers
rgoers's Avatar
I could have used that comment a year ago Pickle...
Live and learn.
2000 440 Panther
1980 Jag 3000 F/C
Old 01-22-2006, 08:51 AM   #10 (permalink)
enrolb
Thanks for all the great advice!
Getting a manual on ebay is something I plan on doing. The alignment marks I will watch for. Now I just need to find a puller!
Old 01-22-2006, 01:30 PM   #11 (permalink)
DitchPickle
Firecat Fanatic
Live and learn.
2004 Firecat F6 EFI
