Old 01-14-2006, 06:10 PM   #1 (permalink)
Liener
Liener's Avatar
F7 acceleration
I am wondering how to set up my sled for a low end/ mid range area. i really want some fast acceleration and good mid range to open up quick in the fields. Any help will be appreciated. thanks, Liener
Liener
Liener is offline   Reply With Quote
Old 01-14-2006, 06:29 PM   #2 (permalink)
BangerBoxoff
Mach Chicken!!
BangerBoxoff's Avatar
there are kits you can get that will keep your front skis down, which increases your topend. the A.D. Bovin suspension kit, my new sled came with it and it has awsome acceleration
BangerBoxoff is offline   Reply With Quote
Old 01-18-2006, 07:12 PM   #3 (permalink)
sesnopro
four gear pinned
sesnopro's Avatar
clutch kit
http://www.hiperf.com/
Old 01-19-2006, 10:39 PM   #4 (permalink)
Liener
Liener's Avatar
ya....i was thinkin more engine.....thanks.......know any good ones that wont empty my bank account.....black magic, holeshot......i dont know what kind haha
Liener
Old 01-21-2006, 09:28 AM   #5 (permalink)
DitchPickle
Firecat Fanatic
DitchPickle's Avatar
What year of sled do you have? Carb or EFI? How much $$$ do you have budgeted?
I can let you know what you need, as soon as I know what you have!!
2004 Firecat F6 EFI
DitchPickle is offline   Reply With Quote
Old 01-21-2006, 03:40 PM   #6 (permalink)
sesnopro
four gear pinned
sesnopro's Avatar
just get a pair of springs from hp, orange/white primary and a green secondary. also some cat 51 gram weights. you can use the stock cat helis with the spring advanced in the 4 slot.
it will run you like 80-100 or so and will be fast.
Old 01-22-2006, 01:18 AM   #7 (permalink)
Liener
Liener's Avatar
Alright thanks....its a 2003 F7 EFI......$300 or under is what i would like to stay in
Liener
Old 01-22-2006, 12:53 PM   #8 (permalink)
DitchPickle
Firecat Fanatic
Sent you a PM - check your INBOX!
2004 Firecat F6 EFI
Old 01-22-2006, 01:10 PM   #9 (permalink)
DitchPickle
Firecat Fanatic
Is this an actual kit or something just put together by someone else? 51g weights is considerably less weight than the stock 63.5g.
Keeping the same helix and adding stiffer springs is gonna make the stock setup over rev as is. Drop the primary weight by 12.5g is gonna make it over rev that much more.
You sure you have the right weight?
EDIT: Do you have any experience with anyone running this setup? What RPM does the sled leave the line at? How about top RPM?
2004 Firecat F6 EFI
Old 01-22-2006, 02:52 PM   #10 (permalink)
sesnopro
four gear pinned
sesnopro's Avatar
thanks dp that was an f5 setup
66s will work better. cat p/n 0746-669
Old 01-23-2006, 12:53 PM   #11 (permalink)
DitchPickle
Firecat Fanatic
No harm intended - just didn't add up!
2004 Firecat F6 EFI
