Old 01-14-2006, 12:09 PM   #1 (permalink)
mx_playa
Sled Head!~
mx_playa's Avatar
crankshaft problems
what kinda of things should I be looking for on a "bad" crankshaft, it is already pulled from the engine.
Joel Kreller (TaCo)
mx_playa is offline   Reply With Quote
Old 01-15-2006, 03:04 PM   #2 (permalink)
bad bearings, score marks, wobble when on a stand ( doesn't roll true)
Old 01-16-2006, 08:42 PM   #3 (permalink)
sesnopro
four gear pinned
sesnopro's Avatar
play in the rods.
http://www.hiperf.com/
Old 01-16-2006, 10:44 PM   #4 (permalink)
rotaxryder
rotaxryder's Avatar
If it looks straight...Check for wear on the crank itself for wear with a micrometer. You can check rod play with a feeler gauge. If the tolerance is off too much from factory specs, it should be replaced. Look for small scratches where the bearings were seated, you can somtimes see them by carefully rubbing a soft piece of copper (like a penny) over them. I don't know if ya have an OEM service manual but maybe someone here could help you out if you don't for specs... Chances are a good polishing is all you need if you really don't have a major crank prob.
This out of the 'ol 340?
rotaxryder is offline   Reply With Quote
Old 01-16-2006, 10:52 PM   #5 (permalink)
mx_playa
Sled Head!~
mx_playa's Avatar
Yep the jag 3000 ice racer haha, time for rebuild
Joel Kreller (TaCo)
Old 01-16-2006, 10:56 PM   #6 (permalink)
rotaxryder
rotaxryder's Avatar
Goodluck dude
Old 01-16-2006, 11:04 PM   #7 (permalink)
mx_playa
Sled Head!~
mx_playa's Avatar
Joel Kreller (TaCo)
