01-10-2006, 04:30 PM
clutch questions (comet)
i have a comet clutch on my pantera 580,
my dad tried a normal jaw puller to attempt to pull it off,
but it chiped a piece of the front plate, then in frustration, tried to uses a hammer, and knocked one of the little fins on the tower that sticks up.
i know its bad b/c the weight distribution is off.
is this a serious problem? and should i get a new clutch?
thanks
_luca
1977 arctic cat pantera
1996 arctic cat pantera 580 efi
1971 ski-doo tnt 292
01-10-2006, 04:46 PM
Papa just made a pile of junk!! You must use the correct tool to remove the clutch. I would suggest that you not even start that engine with the clutch in that condition......it could do a lot of damage to both people & property!! Believe it!!
You will need an entire new clutch assembly.
01-10-2006, 04:49 PM
rrg
dang you dad!
i found on ebay a cover, but the tower is still damaged.
and we do have a correct puller
now.
it took forever to come
01-10-2006, 05:02 PM
Burn Baby Burn !!
Originally posted by luski09
rrg
dang you dad!
now.
check on ebay.. write comet 108 in search.. the'll be ALOT of those... you just put your stuff back in.. or do like i did, use the whole thing and tell your that dad he NEEDS to buy a REAL clutch puller.. which is a bolt basically.. kimpex makes some for 30$
Fr0st
89' Pantera (mr. brownsled), comet 108 CKK clutch, modified exaust...killed by teflon tape in 2004...caught fire in 2005..top speed 80 MPH (speedo) reading.
00' Kawa zx-9 (Lola,the bitch), K&N filter, Muzzys titanium exaust , -1 tooth on front sprocket and pirelli diablos. speed : enough.
2003.5 Mazdaspeed Protege (waazda) - upgraded SMIC, catless downpipe, boostsciences bov,short ram intake and EBC cross drilled and slotted brakes. speed : 130MPH (limited)
01-10-2006, 05:12 PM
OK this is confusing,
i can get the sheave on ebay for 90$
Seave ]Cover[/url]
also the cover
Cover
for 10$
but that one is PN 0646-110
but mine is PN 0646-122
they are the same in the diagram
im pretty sure they are the comet 108 clutch
on ebay whole ones are going for about 50-100
much cheaper than the 400$ new
01-10-2006, 05:19 PM
Burn Baby Burn !!
mine came from a prowler..... i just took off the toher one and bolt on this one.... i played witht he springs alittle and stuff like that but basically it will work right away..
FR0st
01-10-2006, 06:36 PM
It will be cheaper to get the whole thing on eBay, rather than buying pieces. Like others have said, put the guts from yours in the replacement. Make sure the shims and bearings (sleeve inside the weights) are in good shape. The shims are pennies apeice. Bearings are $6 or so. It's worth it to change them (if needed) while you have it apart.
2000 440 Panther
1980 Jag 3000 F/C
01-10-2006, 07:13 PM
rrg
dang you dad!
now.
A jaw puller is NOT the correct puller!! (as you found out)
01-10-2006, 08:15 PM
Burn Baby Burn !!
hey i got a question,
will a comet 108C from another sled like a yamaha or polaris or anything else.. will fit an arctic cat if it's got a 108C ?
Fr0st
01-10-2006, 09:12 PM
You need to know the crank taper of your sled. Go to http://www.hoffcocomet.com/comet/index.asp and that'll give you a list.
01-11-2006, 10:24 PM
bad clutch
do yourself a huge favor and buy a new clutch .
cheaper in long run plus its new. and properly balanced.
if it runs leave the hood closed.
